Re: Re-working the jawa/e50 build.
Alex Hedrick /
> Brandon Weiss (Detective brandon to you) Wrote:
> > Alex Hedrick Wrote:
> > I do have the stock ignition flywheel, plate and coils.. I'm really
> > thinking that's the problem..
> > I mean it's good for a non ripper, good lighting power too. But, I'm
> > gunna buy a new cdi tonight.. i want something with a curve and I
> still
> > need lights..
> > What do you think i go with?
> > I'm thinking hpi mini?? Trying to keep $$ down as this has to be the
> > last thing I get for this thing.
> I wouldnt go hpi unless you get the 300 gram weight with it. I ran the
> mini rotor as is for awhile...and while it did rip, it was not great for
> a daily bike. The rotor is so light, about 1/3 the weight of the
> original, and also way smaller in diameter, so it makes a consistent
> idle damn near impossible not having the momentum to help carry through
> each stroke, especially with high compression setups. Supposedly the
> weight helps the crankshaft bearings last longer as well.
Thanks for that info! Probably just saved me more headache!! I got it the mini with the 300g weight.. I honestly think anything will be better than the treats cdi at this point.
Like I said I like it. For a non ripping moped. But I'm trying to get more out of this setup yet still have it be my semi daily rider.
I noticed on the treats cdi flywheel isnt very "true" as in it has a bit of run out making for one hell of a vibrator at sertant rpms.. no wonder why my girlfriend liked it so much... huh.
You can tell in the video it's almost a mix of a lean bog and ignition troubles.
Will report back in a few days when I get the goods!
  Re-working the jawa/e50 build.Topic by: Alex Hedrick Alex Hedrick 01/14/19 09:18PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/15/19 12:01AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/15/19 10:27AM
  Re: Re-working the jawa/e50 build.Re: Chöschi21 C.K. Chöschi21 C.K. 01/19/19 08:38PM
  Re: Re-working the jawa/e50 build.Re: Daniel '' Daniel '' 01/19/19 09:56PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 01:20AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 05:21AM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 07:26AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 07:45AM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 09:29AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 09:33AM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/20/19 10:44AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 10:48AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/17/19 04:10PM
  Re: Re-working the jawa/e50 build.Re: alex . alex . 01/19/19 05:06AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 07:40AM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/19/19 11:09AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 11:20AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/17/19 04:36PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/17/19 05:07PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/18/19 09:37PM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/19/19 09:37AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 10:34AM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/19/19 04:08PM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/19/19 05:20PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/18/19 09:39PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/18/19 10:31PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 11:06AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 08:46PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 12:24PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 12:39PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 07:13PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 07:14PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 07:22PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 10:21PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 10:26PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 10:44PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 10:58PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/21/19 12:46AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/21/19 12:53AM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/21/19 11:14AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/21/19 11:35AM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/21/19 12:40PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/21/19 03:05PM
  Re: Re-working the jawa/e50 build.Re: alex . alex . 01/21/19 02:40AM
  Re: Re-working the jawa/e50 build.Re: Max Ginsburg Max Ginsburg 01/22/19 04:55AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/22/19 05:16AM
  Re: Re-working the jawa/e50 build.Re: Max Ginsburg Max Ginsburg 01/22/19 06:25AM
  Re: Re-working the jawa/e50 build.Re: kevin Smellaflange kevin Smellaflange 01/24/19 07:31PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 04:32PM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/26/19 06:01PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 06:11PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 07:12PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 07:14PM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/26/19 08:29PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/26/19 08:24PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 08:32PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/26/19 08:25PM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/28/19 02:46PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/28/19 02:49PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/02/19 12:47PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/02/19 01:33PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/03/19 06:53PM
  Re: Re-working the jawa/e50 build.Re: Francois Labat Francois Labat 02/05/19 12:20PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/05/19 12:27PM
  Re: Re-working the jawa/e50 build.Re: Louis Brunskill Louis Brunskill 02/08/19 11:17PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/08/19 11:25PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/11/19 09:13PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/25/19 05:37PM
  Re: Re-working the jawa/e50 build.Re: Bob Selby Bob Selby 03/02/19 05:22PM
