Re: Re-working the jawa/e50 build.
Alex Hedrick /
> Graham Motzing Wrote:
> i didn't see the part about the pietcard box.
> i fried one of these a few years ago and cut it open, turns out the main
> power capacitor in there is rated 150v which is way less than the treat
> cdi is capable of putting out. the components are also sub-garbage.
> they work fine when paired with a low-output Pietcard internal coil, but
> they are likely to get fried hooked up to a treats CDI. The 13 dollar
> 'scrappy dog scooters' Jog cdi works good with the Treat CDI, until the
> trigger coil burns out.
> The treat CDI can be made to work, but woof, its a pain in the ass. Way
> better options out there. Sounds like you are on the right track. I
> have seen them break up at high rpms but they don't sound like that when
> they do... which isn't to say its not possible that is your problem,
> just saying, when i've had them go out, that is not what they sound
> like.
> I would be running points on a setup like that, and certainly first
> thing i would try for trouble shooting is to go back to points to
> eliminate the variable.
Yeah man, totally not the right kind of ignition for this setup.. I mean it does work, but not good enough for me haha. What you are hearing in the video is almost what it was doing before the new 2041 postcard and new pickup coil. I went with the better that treats has. And it did indeed help out a ton. But still having the "lean bog symptoms"
But before with old pietcard and pickup, spark would just cut out totally at high rpm..
I know I could slap points back on it and shred, but what's the fun in that if I dont have to dick with it for another week or so hahaha
MOPEDS!
  Re-working the jawa/e50 build.Topic by: Alex Hedrick Alex Hedrick 01/14/19 09:18PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/15/19 12:01AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/15/19 10:27AM
  Re: Re-working the jawa/e50 build.Re: Chöschi21 C.K. Chöschi21 C.K. 01/19/19 08:38PM
  Re: Re-working the jawa/e50 build.Re: Daniel '' Daniel '' 01/19/19 09:56PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 01:20AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 05:21AM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 07:26AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 07:45AM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 09:29AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 09:33AM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/20/19 10:44AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 10:48AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/17/19 04:10PM
  Re: Re-working the jawa/e50 build.Re: alex . alex . 01/19/19 05:06AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 07:40AM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/19/19 11:09AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 11:20AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/17/19 04:36PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/17/19 05:07PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/18/19 09:37PM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/19/19 09:37AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 10:34AM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/19/19 04:08PM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/19/19 05:20PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/18/19 09:39PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/18/19 10:31PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 11:06AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 08:46PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 12:24PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 12:39PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 07:13PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 07:14PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 07:22PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 10:21PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 10:26PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 10:44PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 10:58PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/21/19 12:46AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/21/19 12:53AM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/21/19 11:14AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/21/19 11:35AM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/21/19 12:40PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/21/19 03:05PM
  Re: Re-working the jawa/e50 build.Re: alex . alex . 01/21/19 02:40AM
  Re: Re-working the jawa/e50 build.Re: Max Ginsburg Max Ginsburg 01/22/19 04:55AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/22/19 05:16AM
  Re: Re-working the jawa/e50 build.Re: Max Ginsburg Max Ginsburg 01/22/19 06:25AM
  Re: Re-working the jawa/e50 build.Re: kevin Smellaflange kevin Smellaflange 01/24/19 07:31PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 04:32PM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/26/19 06:01PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 06:11PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 07:12PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 07:14PM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/26/19 08:29PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/26/19 08:24PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 08:32PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/26/19 08:25PM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/28/19 02:46PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/28/19 02:49PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/02/19 12:47PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/02/19 01:33PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/03/19 06:53PM
  Re: Re-working the jawa/e50 build.Re: Francois Labat Francois Labat 02/05/19 12:20PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/05/19 12:27PM
  Re: Re-working the jawa/e50 build.Re: Louis Brunskill Louis Brunskill 02/08/19 11:17PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/08/19 11:25PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/11/19 09:13PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/25/19 05:37PM
  Re: Re-working the jawa/e50 build.Re: Bob Selby Bob Selby 03/02/19 05:22PM
