Re: Motobecane engine swap?
THANK YOU!!!!
My god plus you put in live links!!! you are a hero!!
No problem dude
Also, here's a helpful write up about snap ring pliers:
http://whiskeythrottlemopeds.blogspot.com/2013/01/motobecane-variator-removal-tool.html
They're required when removing a variator, but I can't remember if you need them for installation or not. Memory says you can just slide the snap ring down the crankshaft and it'll snap into place but it's been a few years since i've worked on one.
Oh and actually I think I have a stock variator in my garage I could sell you if you're interested.
kevin Smellaflange /
you-tube ; dave fixes his shit...
he has 2 25mph moby non-variated models & he goes through exactly what your trying to do, watch his mistakes so you don't waist time...
SHIT! LEGSHIELDS! awesome.
or hit up dos cycles and order them somewhere you'll actually get them, haha.
#76 main jet if you go with a kit.
put a decent k&n style filter
how is your low end take off?
clean out that pipe if you keep the same as the pic, definitely the rubber mounts as they said earlier.
And one of these - but from someone that has one. Or alter yours.
https://www.lucky2strokes.com/product-p/mbk_spring_bracket.htm
> Graham Motzing Wrote:
> I'd also take some time and make sure its tuned up and running right as
> it sits right now. I have zero experience with non variated moby but it
> seems like with the SHA on there you should be able to get 30 out of it.
> top speed should be pretty close to what it would be variated, but the
> acceleration wont be as good. you'd be surprised how much those worn
> out rubber motor mounts can kill performance, all that energy the engine
> is wasting shaking itself apart.
> i'd dig around for a 'how to convert your 50L to 50V thread or wiki
> topic, i'm surprised someone hasn't done that, but off the top of my
> head i can't think of one.
We wrote this up in the WIKI back in 2008
