Re: 15bing or 19phbg on stock za50
Mike Boyd /
Bigger carb will not help a stock setup, if you're tuned and timed right on that 15 bing then you're probably getting as much as you can out of that setup. Since correct timing on 2 speeds can require notching of the the stator plate slots to achieve, I'd start there if you're looking for gains on your current setup.
You could also get a cheap used aluminum stock maxi-style 2HP cylinder and piston and open up the ports and pop that on with that same setup. There's some good info on porting stock cylinders in the Wiki. That would wake it up some and it's a fun learning experience before getting into expensive kits.
  15bing or 19phbg on stock za50Topic by: Jeremy cole Jeremy cole 02/08/19 10:59PM
  Re: 15bing or 19phbg on stock za50Re: Aaron Blair Aaron Blair 02/08/19 11:49PM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/09/19 02:30AM
  Re: 15bing or 19phbg on stock za50Re: Chöschi21 C.K. Chöschi21 C.K. 02/09/19 03:31AM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/09/19 10:37AM
  Re: 15bing or 19phbg on stock za50Re: Mike Boyd Mike Boyd 02/09/19 02:15PM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/09/19 04:48PM
  Re: 15bing or 19phbg on stock za50Re: Overpriced Parts Overpriced Parts 02/10/19 06:19PM
  Re: 15bing or 19phbg on stock za50Re: Graham Motzing Graham Motzing 02/12/19 04:16PM
  Re: 15bing or 19phbg on stock za50Re: Daniel '' Daniel '' 02/15/19 01:50PM
  Re: 15bing or 19phbg on stock za50Re: Mike Boyd Mike Boyd 02/15/19 03:33PM
  Re: 15bing or 19phbg on stock za50Re: Mike Bully Mike Bully 03/12/19 03:55PM
  Re: 15bing or 19phbg on stock za50Re: Graham Motzing Graham Motzing 03/13/19 11:13AM
  Re: 15bing or 19phbg on stock za50Re: Graham Motzing Graham Motzing 02/10/19 09:12AM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/10/19 10:05PM
  Re: 15bing or 19phbg on stock za50Re: Mike Boyd Mike Boyd 02/11/19 04:01PM
  Re: 15bing or 19phbg on stock za50Re: Aaron Blair Aaron Blair 02/11/19 09:33AM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/11/19 07:25PM
  Re: 15bing or 19phbg on stock za50Re: Todd S Todd S 02/14/19 04:29AM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/15/19 10:16AM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/15/19 01:57PM
  Re: 15bing or 19phbg on stock za50Re: Max LGN Max LGN 03/13/19 08:38AM
  Re: 15bing or 19phbg on stock za50Re: EH FCC of the QCB EH FCC of the QCB 03/13/19 09:29AM
