Re: 15bing or 19phbg on stock za50
Jeremy cole /
> Mike Boyd Wrote:
> Bigger carb will not help a stock setup, if you're tuned and timed right
> on that 15 bing then you're probably getting as much as you can out of
> that setup. Since correct timing on 2 speeds can require notching of the
> the stator plate slots to achieve, I'd start there if you're looking for
> gains on your current setup.
> You could also get a cheap used aluminum stock maxi-style 2HP cylinder
> and piston and open up the ports and pop that on with that same setup.
> There's some good info on porting stock cylinders in the Wiki. That
> would wake it up some and it's a fun learning experience before getting
> into expensive kits.
Thanks I've thought about just taking the za50 off and placing in a time capsule lol and putting a e50 on it so I can tune tune tune the engine I have on it now is sweet and is perfect and I really dont wanna ruin it
  15bing or 19phbg on stock za50Topic by: Jeremy cole Jeremy cole 02/08/19 10:59PM
  Re: 15bing or 19phbg on stock za50Re: Aaron Blair Aaron Blair 02/08/19 11:49PM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/09/19 02:30AM
  Re: 15bing or 19phbg on stock za50Re: Chöschi21 C.K. Chöschi21 C.K. 02/09/19 03:31AM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/09/19 10:37AM
  Re: 15bing or 19phbg on stock za50Re: Mike Boyd Mike Boyd 02/09/19 02:15PM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/09/19 04:48PM
  Re: 15bing or 19phbg on stock za50Re: Overpriced Parts Overpriced Parts 02/10/19 06:19PM
  Re: 15bing or 19phbg on stock za50Re: Graham Motzing Graham Motzing 02/12/19 04:16PM
  Re: 15bing or 19phbg on stock za50Re: Daniel '' Daniel '' 02/15/19 01:50PM
  Re: 15bing or 19phbg on stock za50Re: Mike Boyd Mike Boyd 02/15/19 03:33PM
  Re: 15bing or 19phbg on stock za50Re: Mike Bully Mike Bully 03/12/19 03:55PM
  Re: 15bing or 19phbg on stock za50Re: Graham Motzing Graham Motzing 03/13/19 11:13AM
  Re: 15bing or 19phbg on stock za50Re: Graham Motzing Graham Motzing 02/10/19 09:12AM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/10/19 10:05PM
  Re: 15bing or 19phbg on stock za50Re: Mike Boyd Mike Boyd 02/11/19 04:01PM
  Re: 15bing or 19phbg on stock za50Re: Aaron Blair Aaron Blair 02/11/19 09:33AM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/11/19 07:25PM
  Re: 15bing or 19phbg on stock za50Re: Todd S Todd S 02/14/19 04:29AM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/15/19 10:16AM
  Re: 15bing or 19phbg on stock za50Re: Jeremy cole Jeremy cole 02/15/19 01:57PM
  Re: 15bing or 19phbg on stock za50Re: Max LGN Max LGN 03/13/19 08:38AM
  Re: 15bing or 19phbg on stock za50Re: EH FCC of the QCB EH FCC of the QCB 03/13/19 09:29AM
