Re: Tomos A55 carb selection
ben henderson /
> Brandon Weiss (Detective brandon to you) Wrote:
> Whats going on here? You say that you have the stock 14/12 jet in your
> 14 phva? That doesnt make sense, the jets are not interchangeable, the
> phva takes 6mm jets, the SHA take 5mm.
> You cannot just slap a 14/12 or 15/15 SHA onto the A55, the intake will
> not accept it. You would need to craft a spigot so the SHA can be held
> by the rubber intake coupler.
> You should thoroughly clean and tune the PHVA 14 you have instead, its a
> fantastic carb. Stock cylinder with the 14phva and the stock unmodified
> airbox and a biturbo should land you around 57-58 main jet. With a
> metal mesh air filter, somewhere around 62-65, no air filter at all
> somewhere around 68 In my experience
sorry, i was saying that I have a 14/12 sha with the stock jet in it.
The bike came with a homemade intake and had a 14/12 sha on it when I bought it, so I bought a new 14/12 sha to get it running.
I didn't even know until just a couple days ago that I have a A55
I was reading about modding the slide on the SHA carbs to help lean out the midrange...which is where mine seems to be sluggish.
If I cover the half the air intake with tape the midrange becomes more sluggish but the top end feels a bit better. So I think it is running a bit rich in the midrange and lean on the top end. I'm hoping to mod the slide and put in a larger jet to get more power.
When I have a day where the weather is good I plan to do some plug chops at half and full throttle to see if my assumptions are true...then mod the slide/change jet size accordingly.
