Re: Kitted Sachs G3 only going 30mph
Born to be WillD /
wrong spark plug, or timing are 1st guesses, maybe incompletely plugged decomp.
also the intake that comes with the airsal kits is epic heaving shit. I have no idea why but it's significantly shittier than stock. like smaller diameter and the port doesn't line up with the cylinder, it's retarded. but that's not gonna make it go 30. I'm gonna guess 1 of those 3.
1, mayhaps your timing is way off (I run 15-20° BTDC, play with it in there starting at 17).
Also 2, the airsal kit NEEDS a long reach plug, using a B7HS will definitely cut your power by a shitload. ES only.
and 3rd, the decomp: stock ones leak a lot if you reused the old one, it's best to plug it entirely with m10x1.5 and make SURE the bottom of the bolt is bottomed out in the hole, not bottomed out at the cap which could leave the hole open.
Head leaks could be issue here too.
  Kitted Sachs G3 only going 30mphTopic by: Alex Moore Alex Moore 02/12/19 01:12PM
  Re: Kitted Sachs G3 only going 30mphRe: Born to be WillD Born to be WillD 02/12/19 02:24PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/12/19 03:56PM
  Re: Kitted Sachs G3 only going 30mphRe: Born to be WillD Born to be WillD 02/15/19 05:18PM
  Re: Kitted Sachs G3 only going 30mphRe: Chöschi21 C.K. Chöschi21 C.K. 02/12/19 04:27PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/12/19 04:35PM
  Re: Kitted Sachs G3 only going 30mphRe: Chöschi21 C.K. Chöschi21 C.K. 02/12/19 04:55PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/12/19 05:16PM
  Re: Kitted Sachs G3 only going 30mphRe: Chöschi21 C.K. Chöschi21 C.K. 02/12/19 05:51PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/12/19 06:04PM
  Re: Kitted Sachs G3 only going 30mphRe: MPB Andyrew MPB Andyrew 02/13/19 10:19AM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/13/19 01:00PM
  Re: Kitted Sachs G3 only going 30mphRe: MPB Andyrew MPB Andyrew 02/13/19 01:08PM
  Re: Kitted Sachs G3 only going 30mphRe: Chöschi21 C.K. Chöschi21 C.K. 02/13/19 01:20PM
  Re: Kitted Sachs G3 only going 30mphRe: MPB Andyrew MPB Andyrew 02/13/19 04:51PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/13/19 07:42PM
  Re: Kitted Sachs G3 only going 30mphRe: Overpriced Parts Overpriced Parts 02/12/19 05:42PM
  Re: Kitted Sachs G3 only going 30mphRe: Richard Eberline Richard Eberline 02/12/19 09:55PM
  Re: Kitted Sachs G3 only going 30mphRe: pat splat pat splat 02/13/19 03:34PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/13/19 03:59PM
  Re: Kitted Sachs G3 only going 30mphRe: Stephen Simmons Stephen Simmons 02/13/19 04:41PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/13/19 04:48PM
  Re: Kitted Sachs G3 only going 30mphRe: Stephen Simmons Stephen Simmons 02/13/19 05:49PM
  Re: Kitted Sachs G3 only going 30mphRe: Stephen Simmons Stephen Simmons 02/14/19 02:05AM
  Re: Kitted Sachs G3 only going 30mphRe: Titty Bats Titty Bats 02/13/19 11:53PM
  Re: Kitted Sachs G3 only going 30mphRe: Graham Motzing Graham Motzing 02/14/19 12:08PM
  Re: Kitted Sachs G3 only going 30mphRe: Chris Squid Chris Squid 02/14/19 11:04PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/15/19 06:15AM
  Re: Kitted Sachs G3 only going 30mphRe: kenny s kenny s 03/18/19 05:55PM
