Re: Kitted Sachs G3 only going 30mph
Born to be WillD /
1) where's your timing?
Sometimes they were intentionally restricted by running ludicrous advanced timing, like 30 deg BTDC. Also sachs are fairly notorious for shearing the woodruff keys and slipping timing. I blame how fun it is to rip coaster brakes and the not-instant reaction from the clutch to disengage maybe
2) what's the ignition?
my 2-speed D balboa last spring got progressively slower and slower on top speed, had the cheap puch CDI, turned out the timing pickup or something was shitty and it basically just turned off higher rpms. People complain about that happening with those CDIs on puch too. If stock ignition, shitty points, tiny gap or shitty condenser or even a bad lobe on the inside of the flywheel might make it break up at higher speeds.
3) 4 strokey sound at top speeds can also happen if decomps be leaky or small compression leaks. I don't actually know why but I had a leaky decomp that sounded dead ass exactly like 4 stroking, and only appeared at high speed. Stock D w slip-on pipe, bike ran fine up to like 30 then sputter wall sounded just like it was 4 stroking, played all around with jetting and happened same even when the jetting was definitely lean. Then I pulled out the decomp and plugged it, rejetted and she was mid-high 30's
  Kitted Sachs G3 only going 30mphTopic by: Alex Moore Alex Moore 02/12/19 01:12PM
  Re: Kitted Sachs G3 only going 30mphRe: Born to be WillD Born to be WillD 02/12/19 02:24PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/12/19 03:56PM
  Re: Kitted Sachs G3 only going 30mphRe: Born to be WillD Born to be WillD 02/15/19 05:18PM
  Re: Kitted Sachs G3 only going 30mphRe: Chöschi21 C.K. Chöschi21 C.K. 02/12/19 04:27PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/12/19 04:35PM
  Re: Kitted Sachs G3 only going 30mphRe: Chöschi21 C.K. Chöschi21 C.K. 02/12/19 04:55PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/12/19 05:16PM
  Re: Kitted Sachs G3 only going 30mphRe: Chöschi21 C.K. Chöschi21 C.K. 02/12/19 05:51PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/12/19 06:04PM
  Re: Kitted Sachs G3 only going 30mphRe: MPB Andyrew MPB Andyrew 02/13/19 10:19AM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/13/19 01:00PM
  Re: Kitted Sachs G3 only going 30mphRe: MPB Andyrew MPB Andyrew 02/13/19 01:08PM
  Re: Kitted Sachs G3 only going 30mphRe: Chöschi21 C.K. Chöschi21 C.K. 02/13/19 01:20PM
  Re: Kitted Sachs G3 only going 30mphRe: MPB Andyrew MPB Andyrew 02/13/19 04:51PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/13/19 07:42PM
  Re: Kitted Sachs G3 only going 30mphRe: Overpriced Parts Overpriced Parts 02/12/19 05:42PM
  Re: Kitted Sachs G3 only going 30mphRe: Richard Eberline Richard Eberline 02/12/19 09:55PM
  Re: Kitted Sachs G3 only going 30mphRe: pat splat pat splat 02/13/19 03:34PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/13/19 03:59PM
  Re: Kitted Sachs G3 only going 30mphRe: Stephen Simmons Stephen Simmons 02/13/19 04:41PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/13/19 04:48PM
  Re: Kitted Sachs G3 only going 30mphRe: Stephen Simmons Stephen Simmons 02/13/19 05:49PM
  Re: Kitted Sachs G3 only going 30mphRe: Stephen Simmons Stephen Simmons 02/14/19 02:05AM
  Re: Kitted Sachs G3 only going 30mphRe: Titty Bats Titty Bats 02/13/19 11:53PM
  Re: Kitted Sachs G3 only going 30mphRe: Graham Motzing Graham Motzing 02/14/19 12:08PM
  Re: Kitted Sachs G3 only going 30mphRe: Chris Squid Chris Squid 02/14/19 11:04PM
  Re: Kitted Sachs G3 only going 30mphRe: Alex Moore Alex Moore 02/15/19 06:15AM
  Re: Kitted Sachs G3 only going 30mphRe: kenny s kenny s 03/18/19 05:55PM
