tomos Arrow/E50 build. Gearing is weird. Need suggestions.
I'm currently working on a tomos Arrow that has been modified to accept an E50. I am encountering an issue that my rear puch sprocket is welded to the Arrow wheel in order to be compatible with an E50. Obviously I want peak performance out of this guy, but being bound to my 38 tooth rear I'm not entirely sure what I should run on the front sprocket. Suggestions?
Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.
Which dingus welded a sprocket to the wheel?
Chöschi21 C.K. /
Depends what your setup is and what you want out of it.
Steel sprocket welded to an aluminum hub?
Post a photo of that
I assumed he had steel hubbbed spoke wheels, but that would indeed be interesting to see
Apearently, Legion. Supposedly it's a raffle bike.
I'm just going off of what a friend has told me about it when he owned it. I cant actually see the weld, but I can't get it off, I've tried. It's not going anywhere.
Still working on the complete setup. As of now I have it kitted with a 70cc, case and port matched.
The carb is some Bing clone I grabbed from a buddy as a place holder for the time being and just to get it running, but I would like something bigger. I'm thinking a vm20, with an intake to match, but am open to input
I'd like it to be a match for my A35, which pulls 48.5-50 so I'd at least like it to hit 46-48. Id like to have decent low end but I'm not too concerned about being able to rocket out the gate. I just want to avoid minutes long wind ups just to really get going. I have upgraded the clutch springs and offset the clutch pads (can't think of the correct term, I'm inebriated) to help with acceleration.
In general, I've put in the work, I want a fast bike, but not a drag racer, if that makes sense.
The arrow should have a splined rear sprocket held on by a big nut. I would assume the puch sprocket was welded onto the existing tomos sprocket.
A decent picture or two of that hub and sprocket , please , so we don't have to speculate .(edited)
Overpriced Parts /
18x38 may be a good gearing
On a normal e50 case you can grind a little bit to get a 19 tooth on too
The arrow still has the tiny ass wheels? Surely you're not thinking you can gear it like a maxi.
Overpriced Parts /
No
> Ken Roff Wrote:
> you
> No
Has he said this anywhere else? Seems like an assumption.
Not trying to gear it like a maxi. Just trying to gear it with what ive got. Like I said, im bound to a 38 on the arrow wheel due to the weld.
Well, yes you are. The arrow has a teeny tiny rear gear. You are trying to gear it like a puch, with a larger wheel I.E. Maxi or any other Puch. You will never get that bike to go anywhere fast with a 38 rear on a 12" wheel. Go back to the drawing board. What you are bound to is a bike that will do about 46mph screaming it's nuts off and will still be wailing just trying to cruise in the 30s and burning up a bushing crank unless you change that rear gear.
Post a pic of that rear hub/sprocket .
Overpriced Parts /
At 19x38 gears and 12 inch wheel you will be at about 45mph @ 9,000 rpm
https://toolbox.martysgarage.info
Ryan, there's really nothing wrong with a puch that screams to 45mph. Idk how it is in Florida, if you guys have stop lights or hills, but I rarely even get my motorcycle up to 50mph in the city.
But yeah 19 front sprocket barely fits on an e50, a 20t can fit with some dremeling to the cases. Being stuck with a 38 isn't thay bad honestly. I think tomos front sprocket spline is the same as the rear, and they have 22-31 readily available. Just watch the chain line as it might start to drag on the swing arm pivot.
Overpriced Parts /
Daniel your sometimes your intelligence is beyond your years
that sucks, poor arrow...
If you have a good idea of gear ratios then this is simple.
35 rear with a 11 front then you could convert it to (16 x 40).
11 is the smallest I believe you can go on puch. 16x40 is kinda a lot, you could probably run 15x35.
11x38 or 16 x 43.
That is only 2 teeth in the back from stock!
You should have a good starting point from there even on a stock mild kit(edited)
Overpriced Parts /
Read whole post Rocco, Tomos arrow Wheel is only 12 inches in diameter
you really believe in that shit? I remember some kid with a motorized bike was talking to me at the skatepark and he wanted bigger wheels to gain mph, I wanted to tell him just to slap a kit and pipe on it but I keep my mouth shut. we are talking about 5" never mind weight its not going to effect much.
the kids got a 70cc kit I think at 11x38 or aka 16 x43 he will be very happy
It's a 34.48% difference and that's before you consider the difference in tire height.
Overpriced Parts /
> in tire height.
Yeah Rocco’s a little bit behind at times as far as experience goes!
Gear for the power band means everything! and this is me telling you from the mid-70s with Kawasaki 100s and other small displacement bikes!
gear for your powerband that’s all I could say !
> Ken Roff Wrote:
> > in tire height.
Gearing for powerband is part of it not the entire pie. Without a doubt I have 0 experience but I think your to worried about A bike that Will easily pull those gears but I also only weigh 155lbs
Dirty30 Dillon /
> Rocco Taco Wrote:
> > Ken Roff Wrote:
> difference
> > > in tire height.
> bikes!
Of course it will have no problem, because it is super short gearing. The problem is not pulling tall gearing, it's about being stuck in over-rev at 43.4 mph
Right, the bike will be wheezing at 2/3 of it's potential top speed and causing a lot of heat buildup and wear with the potential failures far more likely. And for what, to cruise at 32 mph with a top speed just over 40?
This is exactly the reason I literally put my NC50 to the curb after tons of tinkering with exhaust work, porting, intake and carb etc. I got it to do 43mph on the stock cylinder but it was howling to even go 35 and the heat buildup had me shutting it down after a couple of miles just cruising. I am not trying to specifically compare the two instances because the cooling ability of the two engines will be significantly different but it was the realization that I was stuck with a fixed ratio that I would never be able to see the potential of the build. Even trying to casually ride the bike in the way I wanted (cruising 40-45) was going to result in a lot of heartache when it turned out to be a grenade every time.
God some of you people dont know anything! Ken even dropped the numbers in the tool box calculator for y'all. 18x38 is a nice ratio with 12 inch tires, 45mph is just under 9k.
Ryan, you have obviously never fucked with a puch with a stock gears. So get the fuck out of this thread with you express anecdotes. 17x45 is a ratio you can hit +55 on.
