I did have to lighten the weights a bunch, 15g down to 12.
I control shift with my variator brake so as long as my weights aren't way too heavy I just control everything manually. It makes for a very fast bike.
I would have preferred to just cut the variator but couldn't get the belt height I needed that way alone because the TJT doesn't have enough meat to cut out without destroying itself.. I still gotta braze and fix the one I fucked up by cutting too far.
If there were 15mm belts in standard AX sizes I wouldn't have to deal with this bullshit.
