Re: Puch Maxi rebuild
Max LGN /
Bolts come loose, gaskets fail, things happen and an air leak can occur. I'd rather spend the $40 on a gauge and have the piece of mind. It's such a simple thing to install and use.
Also, you can fine tune your bike even better with a gauge. You might be getting 35mph out of your bike now, but how do you know it cant run leaner and hit 38mph? How do you know you are at optimal operating temp? A gauge will let you safely push the limits. Not saying you need one, but there is a reason they are popular.
> Chöschi21 C.K. Wrote:
> Everybody is always talking about seizing a kit and having to use a Head
> temp Gauge, why? Seized one cylinder because of going far to lean with
> to much compression, never used a temp gauge, even when revving
> 11'000@35mph with a Squishgap of 0.8mm i didn't have any problems.
  Puch Maxi rebuildTopic by: Maserat Maserat Maserat Maserat 02/26/19 08:13PM
  Re: Puch Maxi rebuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/26/19 09:09PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:13PM
  Re: Puch Maxi rebuildRe: Lee Snover Lee Snover 09/10/19 06:43AM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 09:55AM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:15PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:21PM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 09:59AM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 02:16PM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 02:50PM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 03:51PM
  Re: Puch Maxi rebuildRe: Dirty30 Dillon Dirty30 Dillon 02/27/19 05:16PM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 05:58PM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 04:14PM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 04:25PM
  Re: Puch Maxi rebuildRe: Graham Motzing Graham Motzing 02/27/19 05:05PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:18PM
  Re: Puch Maxi rebuildRe: Mike Boyd Mike Boyd 02/27/19 08:25PM
  Re: Puch Maxi rebuildRe: Alex hernandez Alex hernandez 02/28/19 04:31PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 03/09/19 11:46AM
  Re: Puch Maxi rebuildRe: Adam Smith Adam Smith 03/09/19 03:12PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/07/19 12:56PM
  Re: Puch Maxi rebuildRe: Adam Smith Adam Smith 09/07/19 01:20PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/07/19 01:28PM
  Re: Puch Maxi rebuildRe: Overpriced Parts Overpriced Parts 09/07/19 05:06PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/07/19 05:48PM
  Re: Puch Maxi rebuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 09/07/19 09:04PM
  Re: Puch Maxi rebuildRe: Alex hernandez Alex hernandez 09/08/19 02:49PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:05AM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:04AM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 09/07/19 06:44PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:00AM
  Re: Puch Maxi rebuildRe: Mel FromZelie Mel FromZelie 09/09/19 01:41PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 02:41PM
  Re: Puch Maxi rebuildRe: Mel FromZelie Mel FromZelie 09/09/19 04:41PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 05:54PM
  Re: Puch Maxi rebuildRe: Mel FromZelie Mel FromZelie 09/09/19 08:43PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:09AM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/10/19 07:27PM
