Re: Puch Maxi rebuild
Maserat Maserat /
> Chöschi21 C.K. Wrote:
> What Setup are you running? 33 with 15:45 seems very slow for a kitted
> Puch.
I installed a unstuffed race crank with bearings, a treats party 70cc piston and cyl, a treats touring head, 15mm bing with 79 main jet, I used an o ring to stop the bing to manifold leak, treats #1 grandpa manifold, high flow air filter, all new bearings and seals, matched the case ports to the new cyl, Proma Circuit pipe, for timing I had to dremel the stator to get it down to 17 degrees, I used a dial indicator to find tdc. Any advice will be greatly appreciated!
  Puch Maxi rebuildTopic by: Maserat Maserat Maserat Maserat 02/26/19 08:13PM
  Re: Puch Maxi rebuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/26/19 09:09PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:13PM
  Re: Puch Maxi rebuildRe: Lee Snover Lee Snover 09/10/19 06:43AM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 09:55AM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:15PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:21PM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 09:59AM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 02:16PM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 02:50PM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 03:51PM
  Re: Puch Maxi rebuildRe: Dirty30 Dillon Dirty30 Dillon 02/27/19 05:16PM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 05:58PM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 04:14PM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 04:25PM
  Re: Puch Maxi rebuildRe: Graham Motzing Graham Motzing 02/27/19 05:05PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:18PM
  Re: Puch Maxi rebuildRe: Mike Boyd Mike Boyd 02/27/19 08:25PM
  Re: Puch Maxi rebuildRe: Alex hernandez Alex hernandez 02/28/19 04:31PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 03/09/19 11:46AM
  Re: Puch Maxi rebuildRe: Adam Smith Adam Smith 03/09/19 03:12PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/07/19 12:56PM
  Re: Puch Maxi rebuildRe: Adam Smith Adam Smith 09/07/19 01:20PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/07/19 01:28PM
  Re: Puch Maxi rebuildRe: Overpriced Parts Overpriced Parts 09/07/19 05:06PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/07/19 05:48PM
  Re: Puch Maxi rebuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 09/07/19 09:04PM
  Re: Puch Maxi rebuildRe: Alex hernandez Alex hernandez 09/08/19 02:49PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:05AM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:04AM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 09/07/19 06:44PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:00AM
  Re: Puch Maxi rebuildRe: Mel FromZelie Mel FromZelie 09/09/19 01:41PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 02:41PM
  Re: Puch Maxi rebuildRe: Mel FromZelie Mel FromZelie 09/09/19 04:41PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 05:54PM
  Re: Puch Maxi rebuildRe: Mel FromZelie Mel FromZelie 09/09/19 08:43PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:09AM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/10/19 07:27PM
