> Chöschi21 C.K. Wrote:
> What Setup are you running? 33 with 15:45 seems very slow for a kitted
> Puch.
I installed a unstuffed race crank with bearings, a treats party 70cc piston and cyl, a treats touring head, 15mm bing with 79 main jet, I used an o ring to stop the bing to manifold leak, treats #1 grandpa manifold, high flow air filter, all new bearings and seals, matched the case ports to the new cyl, Proma Circuit pipe, for timing I had to dremel the stator to get it down to 17 degrees, I used a dial indicator to find tdc. Any advice will be greatly appreciated!
