Re: Puch Maxi rebuild
Maserat Maserat /
> Mel FromZelie Wrote:
> We just redid my '77 with very a very similar setup.
> 70cc Treats party with the "custom cut sport/touring" head. 15mm bing
> (with MLM intake and air filter).
> techno circuit (not proma circuit) pipe - so close.
> Our timing is at around 14.5-15ish. 14-45 gears (stock). We get 38 mph
> out of it on the flat, max.. We have an 85 jet in it... it does 4-stroke
> a little at the top end- I have an 84 on order.
> My concern is heat - what temps are you getting? When I drive it up a
> big (and we have *steep* hills here) - we are close to 400. Normal
> operating like 340. I changed the front gear to 16, but it didn't
> really help with the heat, and really made it sluggish on take-off.
> Treats said it should be in the 320-340 operating normally... but we
> shouldn't be pushing the 400.
Our hills are on the steep side, The highest temp I reached was 385, it normally runs from high 200s to low 300s I was four stroking at full throttle down to an 83 jet I haven't done a plug chop yet but I will play around with jetting a little more. Also I read somewhere that guys are running in the low 400s with no issue.
  Puch Maxi rebuildTopic by: Maserat Maserat Maserat Maserat 02/26/19 08:13PM
  Re: Puch Maxi rebuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/26/19 09:09PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:13PM
  Re: Puch Maxi rebuildRe: Lee Snover Lee Snover 09/10/19 06:43AM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 09:55AM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:15PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:21PM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 09:59AM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 02:16PM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 02:50PM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 03:51PM
  Re: Puch Maxi rebuildRe: Dirty30 Dillon Dirty30 Dillon 02/27/19 05:16PM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 05:58PM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 04:14PM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 04:25PM
  Re: Puch Maxi rebuildRe: Graham Motzing Graham Motzing 02/27/19 05:05PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:18PM
  Re: Puch Maxi rebuildRe: Mike Boyd Mike Boyd 02/27/19 08:25PM
  Re: Puch Maxi rebuildRe: Alex hernandez Alex hernandez 02/28/19 04:31PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 03/09/19 11:46AM
  Re: Puch Maxi rebuildRe: Adam Smith Adam Smith 03/09/19 03:12PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/07/19 12:56PM
  Re: Puch Maxi rebuildRe: Adam Smith Adam Smith 09/07/19 01:20PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/07/19 01:28PM
  Re: Puch Maxi rebuildRe: Overpriced Parts Overpriced Parts 09/07/19 05:06PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/07/19 05:48PM
  Re: Puch Maxi rebuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 09/07/19 09:04PM
  Re: Puch Maxi rebuildRe: Alex hernandez Alex hernandez 09/08/19 02:49PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:05AM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:04AM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 09/07/19 06:44PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:00AM
  Re: Puch Maxi rebuildRe: Mel FromZelie Mel FromZelie 09/09/19 01:41PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 02:41PM
  Re: Puch Maxi rebuildRe: Mel FromZelie Mel FromZelie 09/09/19 04:41PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 05:54PM
  Re: Puch Maxi rebuildRe: Mel FromZelie Mel FromZelie 09/09/19 08:43PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:09AM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/10/19 07:27PM
