Re: Puch Maxi rebuild
Maserat Maserat /
> Mel FromZelie Wrote:
> I blew up my kstar kit (that came on the bike when I bought it) when I
> hit around 416 this summer.. but I also had a massive air leak
> unbeknownst to me at the time... hence the total rebuild.. so I am a
> little skittish about temps at this point.
I'm sure the vacuum leak killed it, I check for leaks after any change but still ended up with one at the carb to intake connection which caused me grief thinking it was a jetting issue. I did some reading about how the exhaust gasses work on a 2 stroke and how advanced timing will hurt the top end, I'm going to play with timing to see if I can get it down from 17 to 15. Did you change your crank?
  Puch Maxi rebuildTopic by: Maserat Maserat Maserat Maserat 02/26/19 08:13PM
  Re: Puch Maxi rebuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/26/19 09:09PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:13PM
  Re: Puch Maxi rebuildRe: Lee Snover Lee Snover 09/10/19 06:43AM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 09:55AM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:15PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:21PM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 09:59AM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 02:16PM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 02:50PM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 03:51PM
  Re: Puch Maxi rebuildRe: Dirty30 Dillon Dirty30 Dillon 02/27/19 05:16PM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 05:58PM
  Re: Puch Maxi rebuildRe: Max LGN Max LGN 02/27/19 04:14PM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 02/27/19 04:25PM
  Re: Puch Maxi rebuildRe: Graham Motzing Graham Motzing 02/27/19 05:05PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 02/27/19 06:18PM
  Re: Puch Maxi rebuildRe: Mike Boyd Mike Boyd 02/27/19 08:25PM
  Re: Puch Maxi rebuildRe: Alex hernandez Alex hernandez 02/28/19 04:31PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 03/09/19 11:46AM
  Re: Puch Maxi rebuildRe: Adam Smith Adam Smith 03/09/19 03:12PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/07/19 12:56PM
  Re: Puch Maxi rebuildRe: Adam Smith Adam Smith 09/07/19 01:20PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/07/19 01:28PM
  Re: Puch Maxi rebuildRe: Overpriced Parts Overpriced Parts 09/07/19 05:06PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/07/19 05:48PM
  Re: Puch Maxi rebuildRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 09/07/19 09:04PM
  Re: Puch Maxi rebuildRe: Alex hernandez Alex hernandez 09/08/19 02:49PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:05AM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:04AM
  Re: Puch Maxi rebuildRe: Chöschi21 C.K. Chöschi21 C.K. 09/07/19 06:44PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:00AM
  Re: Puch Maxi rebuildRe: Mel FromZelie Mel FromZelie 09/09/19 01:41PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 02:41PM
  Re: Puch Maxi rebuildRe: Mel FromZelie Mel FromZelie 09/09/19 04:41PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 05:54PM
  Re: Puch Maxi rebuildRe: Mel FromZelie Mel FromZelie 09/09/19 08:43PM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/09/19 08:09AM
  Re: Puch Maxi rebuildRe: Maserat Maserat Maserat Maserat 09/10/19 07:27PM
