Lowering compression on a Moby
What's the best way compression on a Moby without stacking base gaskets? Possibly mill the head?
Re: Lowering compression on a Moby
Milling the piston may work as well if you have experience on the lathe. Either taking off the top dome or milling a dish into it
Why? Get a better head and you won't need to. I've fucked with stock heads a lot to change shit and I've realized that stock heads are mostly garbage. Most have no squish or very little.
Get a decent squish band head and you can run whatever comp you want if you plan for it
