Re: Mbk 51 project
NEMA Victor (3 Knees Down) /
> Jesse Simonsen Wrote:
> I think I may need to make the pivot rod longer because if I bring the
> pipe up any higher it interferes with the spring.
> Do you know if people usually use the longer (843mm) belts with this
> spring setup?
> I have a malossi and Doppler av10 belt and with them the spring will
> need around an inch or more preload to mount
> under the frame with a bracket.
> Once I get the spring mounted I can move on to the exhaust mount and
> d check baffle clearance
Doppler belt is too short and narrow, throw it away. Bando belt is almost perfect. Just a touch too long unless you really setup the engine properly. The angle and width is perfect for bidalot vario, it will stick out the top of doppler pulley and vario however (not a huge deal though). Also works best on malossi vario.
As for your spring issue, I think you have the spring installed incorrectly. It needs to be more forward on the engine; looks like it's set back. If you move it forward, the pipe should clear and once you readjust your frame mount for the spring it will make the belt a bit tighter. (See photo)
Don't run a longer exhaust arm. Longer means it will get lower faster and probably hit the floor in a turn. You want it shorter (even shorter than the stock doppler length). But a rule of thumb I've followed is to make the exhaust arm straight at almost to full variation and make sure the exhaust ball joint is inline with the exhaust that way as well so it's properly doing it's job without kinks. Hope this helps.
  Mbk 51 projectTopic by: Jesse Simonsen Jesse Simonsen 04/03/19 09:47PM
  Re: Mbk 51 projectRe: pat splat pat splat 04/03/19 11:22PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 04/03/19 11:39PM
  Re: Mbk 51 projectRe: P D P D 04/04/19 10:24AM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 04/04/19 02:48PM
  Re: Mbk 51 projectRe: P D P D 04/04/19 03:59PM
  Re: Mbk 51 projectRe: Graham Motzing Graham Motzing 04/04/19 04:20PM
  Re: Mbk 51 projectRe: Ben Whittle Ben Whittle 04/04/19 10:10PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 04/05/19 12:49AM
  Re: Mbk 51 projectRe: P D P D 04/05/19 11:06AM
  Re: Mbk 51 projectRe: Yung Spil Yung Spil 04/08/19 08:51PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 04/08/19 10:40PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 09/22/19 09:42PM
  Re: Mbk 51 projectRe: Johnnie Distefano Johnnie Distefano 09/23/19 10:18AM
  Re: Mbk 51 projectRe: Cristian Luna Cristian Luna 09/27/19 02:06PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 09/27/19 02:24PM
  Re: Mbk 51 projectRe: Anonymous User Anonymous User 09/28/19 11:45PM
  Re: Mbk 51 projectRe: Daniel '' Daniel '' 09/29/19 01:05AM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 09/29/19 01:14AM
  Re: Mbk 51 projectRe: Rebel Moby Rebel Moby 10/04/19 10:01AM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 10/07/19 01:47AM
  Re: Mbk 51 projectRe: Anonymous User Anonymous User 10/08/19 01:45PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 09/29/19 01:08AM
  Re: Mbk 51 projectRe: Anonymous User Anonymous User 09/29/19 09:14AM
  Re: Mbk 51 projectRe: Johnnie Distefano Johnnie Distefano 09/29/19 01:18PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 09/29/19 01:41PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 10/28/19 12:32AM
  Re: Mbk 51 projectRe: Rebel Moby Rebel Moby 10/28/19 10:22AM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 10/28/19 02:46PM
  Re: Mbk 51 projectRe: Jesse Gomez Jesse Gomez 11/09/19 09:54AM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 11/09/19 12:10PM
  Re: Mbk 51 projectRe: P D P D 11/09/19 12:36PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 11/09/19 01:18PM
  Re: Mbk 51 projectRe: P D P D 11/09/19 01:43PM
  Re: Mbk 51 projectRe: Blake MD No PM Plz Blake MD No PM Plz 11/09/19 02:14PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 11/09/19 04:33PM
  Re: Mbk 51 projectRe: P D P D 11/09/19 05:28PM
  Re: Mbk 51 projectRe: niklaus _ niklaus _ 11/09/19 10:03PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 11/09/19 11:37PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 11/10/19 10:55PM
  Re: Mbk 51 projectRe: Anonymous User Anonymous User 11/11/19 07:46AM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 11/11/19 09:22AM
  Re: Mbk 51 projectRe: jordan * jordan * 11/11/19 01:22PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 11/11/19 01:47PM
  Re: Mbk 51 projectRe: Johnnie Distefano Johnnie Distefano 11/13/19 09:28AM
  Re: Mbk 51 projectRe: Blake MD No PM Plz Blake MD No PM Plz 11/13/19 02:37PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 11/13/19 07:04PM
  Re: Mbk 51 projectRe: Blake MD No PM Plz Blake MD No PM Plz 11/13/19 07:20PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 11/25/19 12:15AM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 12/09/19 01:03AM
  Re: Mbk 51 projectRe: * * * * 12/09/19 06:41AM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 12/09/19 08:00AM
  Re: Mbk 51 projectRe: * * * * 12/09/19 11:03PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 12/09/19 11:39PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 12/10/19 11:50PM
  Re: Mbk 51 projectRe: * * * * 12/11/19 04:53PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 12/12/19 01:53AM
  Re: Mbk 51 projectRe: Daniel '' Daniel '' 12/12/19 02:10AM
  Re: Mbk 51 projectRe: Dickie Thompson Dickie Thompson 12/13/19 05:00PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 12/13/19 11:52PM
  Re: Mbk 51 projectRe: Daniel '' Daniel '' 12/13/19 11:57PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 12/14/19 07:56AM
  Re: Mbk 51 projectRe: Rebel Moby Rebel Moby 12/14/19 09:52AM
  Re: Mbk 51 projectRe: P D P D 12/14/19 10:08AM
  Re: Mbk 51 projectRe: Rebel Moby Rebel Moby 12/14/19 10:14AM
  Re: Mbk 51 projectRe: P D P D 12/14/19 10:34AM
  Re: Mbk 51 projectRe: Rebel Moby Rebel Moby 12/14/19 03:11PM
  Re: Mbk 51 projectRe: P D P D 12/14/19 07:16PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 12/14/19 10:50AM
  Re: Mbk 51 projectRe: * * * * 12/15/19 02:15AM
  Re: Mbk 51 projectRe: Joel P Joel P 12/15/19 10:59AM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 12/15/19 11:38AM
  Re: Mbk 51 projectRe: Blake MD No PM Plz Blake MD No PM Plz 12/14/19 10:19AM
  Re: Mbk 51 projectRe: EH FCC of the QCB EH FCC of the QCB 12/14/19 06:53PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 12/12/19 07:40AM
  Re: Mbk 51 projectRe: Joel P Joel P 12/28/19 09:11PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 12/28/19 10:09PM
  Re: Mbk 51 projectRe: The Dude The Dude 12/28/19 09:26PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 12/28/19 10:37PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 01/06/20 01:14AM
  Re: Mbk 51 projectRe: Ryan Graeme Ryan Graeme 01/06/20 01:10PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 01/06/20 01:27PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 01/12/20 11:13PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 02/10/20 12:19AM
  Re: Mbk 51 projectRe: reynie domingo reynie domingo 02/10/20 10:38AM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 02/10/20 09:50PM
  Re: Mbk 51 projectRe: reynie domingo reynie domingo 02/10/20 10:19PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 02/10/20 10:37PM
  Re: Mbk 51 projectRe: reynie domingo reynie domingo 02/10/20 10:52PM
  Re: Mbk 51 projectRe: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 02/10/20 11:46AM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 02/10/20 01:33PM
  Re: Mbk 51 projectRe: reynie domingo reynie domingo 02/10/20 03:32PM
  Re: Mbk 51 projectRe: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 02/11/20 12:02AM
  Re: Mbk 51 projectRe: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 02/11/20 12:06AM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 02/11/20 01:03AM
  Re: Mbk 51 projectRe: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 02/11/20 12:41PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 02/12/20 10:08PM
  Re: Mbk 51 projectRe: Jesse Simonsen Jesse Simonsen 03/07/20 09:41PM
