> Graham Motzing Wrote:
> also reports of destroyed a35 clutches are greatly exaggerated.. the
> cork goes to shit and they pop out of the groove in the hub, then the
> pins aren't supported and they break.
> if you re-line them with anything but pure garbage cork, make sure your
> leaking output shaft doesn't puke out all the oil, and don't keep power
> shifting it after the pads are worn and its dry of oil... they can take
> a surprising amount of power.
> if you build a motor that makes good torque, which is easy with the reed
> valve, and you leave them shifting at relatively low rpm, they are just
> fine. and don't put a damn HPI on there since that destroys them double
> extra fast.
> tomos are easy so they tend to attract all the morons, then they break
> them and bitch about it. go check out lovers of tomos on facebook, its
> the short bus of mopeds.
Yea I had an a55 so I have a little experience with tomos but I’m in that group and I’ve seen the conversations
