Carb upgrade for stock-ish qt50 as first mod.
Rob LaFreniere /
I just bought what I hope is a stock 1984 qt50 and want to upgrade it to eventually be fast enough to safely commute to work. I think that 40mph would be bare minimum.
I have had bad experiences making more than one mod at a time to previous vehicles that frequently resulted in frustration and un-met expectations. This time I will try to only do one performance upgrade at a time.
My first major step, after fixing the brakes and the faulty pet-cock and replacing the air filter with an aftermarket foam thing, will be a carburetor. Based on what I've gleaned from here, youtube, and Mr. Rutherford's site, I think the Mikuni vm20 + mlm intake would work for the long haul.
The one question I could not find an answer to is what jet sizes should I start with considering that the only thing I've done is added a less restrictive air filter?
regards,
Rob
  Carb upgrade for stock-ish qt50 as first mod.Topic by: Rob LaFreniere Rob LaFreniere 04/10/19 04:14PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/10/19 08:16PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Rob LaFreniere Rob LaFreniere 04/11/19 11:49AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/11/19 07:06PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/13/19 04:38AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/13/19 10:03PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/11/19 07:16PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/11/19 08:54PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/11/19 07:26PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/11/19 11:53PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/12/19 12:06AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Rob LaFreniere Rob LaFreniere 04/12/19 09:33AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/12/19 07:24PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/12/19 10:50PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Rand Jacobson Rand Jacobson 04/13/19 07:02PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/14/19 04:37AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/15/19 07:26PM
