Re: Carb upgrade for stock-ish qt50 as first mod.
Bill Mazzacane /
> Jack Rutherford Wrote:
> 41.5mph with stock carb, mlm circuit pipe and 1.5mm spacer on
> stock cylinder.
I am curious, you added the 1.5mm plate and raised exhaust and transfer ports, but you didn't increase the BDT? BDT is really important.
Did you at least remove 1.5mm / .060" from the top of the cylinder to compensate for the 40 to 60 psi in compression that was lost?
What was the final squish clearance?
Bill M.
  Carb upgrade for stock-ish qt50 as first mod.Topic by: Rob LaFreniere Rob LaFreniere 04/10/19 04:14PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/10/19 08:16PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Rob LaFreniere Rob LaFreniere 04/11/19 11:49AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/11/19 07:06PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/13/19 04:38AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/13/19 10:03PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/11/19 07:16PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/11/19 08:54PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/11/19 07:26PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/11/19 11:53PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/12/19 12:06AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Rob LaFreniere Rob LaFreniere 04/12/19 09:33AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/12/19 07:24PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/12/19 10:50PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Rand Jacobson Rand Jacobson 04/13/19 07:02PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/14/19 04:37AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/15/19 07:26PM
