Re: Carb upgrade for stock-ish qt50 as first mod.
Bill Mazzacane /
Jack Rutherford my comments are directed at the OP, not you. I used your posts to prove my point that adding only a pipe to a QT, will not provide decent HP.
You did a lot of extra work.
Too much work in my opinion.
> Bill Mazzacane Wrote:
> 18 degrees of BDT is the absolute minimum,
> but I wouldn't waste my time building or selling a
> tuned pipe unless the customer knew that changing BDT was essential to
> the performance of the engine.
> I don't know these companies, but if you (the OP) are under the opinion that you
> can bolt a pipe on to any stock cylinder and get decent HP, that isn't
> true.
> Bill M. (edited)
  Carb upgrade for stock-ish qt50 as first mod.Topic by: Rob LaFreniere Rob LaFreniere 04/10/19 04:14PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/10/19 08:16PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Rob LaFreniere Rob LaFreniere 04/11/19 11:49AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/11/19 07:06PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/13/19 04:38AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/13/19 10:03PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/11/19 07:16PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/11/19 08:54PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/11/19 07:26PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/11/19 11:53PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/12/19 12:06AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Rob LaFreniere Rob LaFreniere 04/12/19 09:33AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/12/19 07:24PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/12/19 10:50PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Rand Jacobson Rand Jacobson 04/13/19 07:02PM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Bill Mazzacane Bill Mazzacane 04/14/19 04:37AM
  Re: Carb upgrade for stock-ish qt50 as first mod.Re: Jack Rutherford Jack Rutherford 04/15/19 07:26PM
