The main being drilled out would explain why I have been able to get away with such a lean jet. Yes, the exhaust is a technigas.
Do you think I should start with a 100 and work my way down after I finish the rebuild? Or should I start lower? I ordered a trail tech vapor with a temp sensor so I should be able to keep an eye on the temps.
I am trying to go all out with this build.
