Kitted a3 performance. Where is it at
Matthew Fickett /
I have a bullet with a3 motor, treats 70cc airsal part kit. it has the high compression head 20mm Mikuni Vm20 intake...also Biturbo exhaust, 27/22 sprockets, a55 flywheel and parmakit cdi.
I’m hitting only 40/41 max. Gets there quick but a lot of people say it should be getting a lot more even on close to stock setup. I’ve done plug chops and it looks healthy golden brown. I had some gy6 jets laying around that fit the carb and tried going bigger and smaller with no real difference. (Yes I know the jet sizes between the Mikuni and gy6 are different)
I’m times to 2.8btdc and thinking about going down to 1.8 or trying something in between once I get my temp gauge in.
Also was thinking of doing a 30 and 20 sprocket for max full send. I’m not running a smaller magnito but everything I’ve seen 30 will clear the wheel with just some case grinding and the back wheel as well.
Am I at the bikes best or the engines best?
Top end and cases have all been redone and kit is new. Been putting on some nice break in miles.
Is the carb that came with the kit too big? Maybe run a more restricted air filter?
Again, when I got the bike it had the kit on it. Had to replace the kit from the previous owner improperly installing it. I’ve been trying to make the bike better and it’s getting there but I feel like it has a taaaaad more.
YES SIR YEEEHAAA!!
Thoughts?
  Kitted a3 performance. Where is it atTopic by: Matthew Fickett Matthew Fickett 04/21/19 08:04PM
  Re: Kitted a3 performance. Where is it atRe: Mike Boyd Mike Boyd 04/21/19 08:19PM
  Re: Kitted a3 performance. Where is it atRe: Chris Szuba Chris Szuba 04/22/19 07:58AM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/22/19 08:12AM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/22/19 02:12PM
  Re: Kitted a3 performance. Where is it atRe: Saabsonettguy . Saabsonettguy . 04/22/19 02:08PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/22/19 02:11PM
  Re: Kitted a3 performance. Where is it atRe: pat splat pat splat 04/25/19 02:28PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/25/19 02:39PM
  Re: Kitted a3 performance. Where is it atRe: Daniel '' Daniel '' 04/26/19 10:54AM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/26/19 11:00AM
  Re: Kitted a3 performance. Where is it atRe: Daniel '' Daniel '' 04/26/19 11:02AM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/26/19 11:06AM
  Re: Kitted a3 performance. Where is it atRe: Daniel '' Daniel '' 04/26/19 11:37AM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/26/19 11:38AM
  Re: Kitted a3 performance. Where is it atRe: Conan Segar Conan Segar 04/25/19 02:33PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/25/19 02:54PM
  Re: Kitted a3 performance. Where is it atRe: Josiah Radebaugh Josiah Radebaugh 04/26/19 01:00PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/30/19 05:54PM
  Re: Kitted a3 performance. Where is it atRe: Mike Boyd Mike Boyd 04/30/19 07:43PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/30/19 08:31PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/30/19 05:56PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 05/01/19 06:25PM
