Re: Kitted a3 performance. Where is it at
Daniel '' /
A stock a3 with a biturbo and that gearing does over 40. I'd check the compression, it might be way too high with the hihi head. Jetting should be in the 135-155 range with a filter. As far as timing 2.8mm btdc is pretty hot for a tomos, unless you know what the retard curve of it is like. I've never used one of those myself. Usually with the fancier cdi you set them at max advance and it does the rest magically, but sometimes they're static and then retard from there at a pre designated rpm.
  Kitted a3 performance. Where is it atTopic by: Matthew Fickett Matthew Fickett 04/21/19 08:04PM
  Re: Kitted a3 performance. Where is it atRe: Mike Boyd Mike Boyd 04/21/19 08:19PM
  Re: Kitted a3 performance. Where is it atRe: Chris Szuba Chris Szuba 04/22/19 07:58AM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/22/19 08:12AM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/22/19 02:12PM
  Re: Kitted a3 performance. Where is it atRe: Saabsonettguy . Saabsonettguy . 04/22/19 02:08PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/22/19 02:11PM
  Re: Kitted a3 performance. Where is it atRe: pat splat pat splat 04/25/19 02:28PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/25/19 02:39PM
  Re: Kitted a3 performance. Where is it atRe: Daniel '' Daniel '' 04/26/19 10:54AM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/26/19 11:00AM
  Re: Kitted a3 performance. Where is it atRe: Daniel '' Daniel '' 04/26/19 11:02AM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/26/19 11:06AM
  Re: Kitted a3 performance. Where is it atRe: Daniel '' Daniel '' 04/26/19 11:37AM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/26/19 11:38AM
  Re: Kitted a3 performance. Where is it atRe: Conan Segar Conan Segar 04/25/19 02:33PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/25/19 02:54PM
  Re: Kitted a3 performance. Where is it atRe: Josiah Radebaugh Josiah Radebaugh 04/26/19 01:00PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/30/19 05:54PM
  Re: Kitted a3 performance. Where is it atRe: Mike Boyd Mike Boyd 04/30/19 07:43PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/30/19 08:31PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 04/30/19 05:56PM
  Re: Kitted a3 performance. Where is it atRe: Matthew Fickett Matthew Fickett 05/01/19 06:25PM
