Anyboby made one?
Hobbit motomatic pulley
Re: Hobbit motomatic pulley
Yeah, Motomatic.
Anyboby!!!
ANYBOBY!!!!!!
Noboby has .
Any issues with breaking welds? I know you need the guts off a stock hobbit pulley and weld it in but it also needs some affixing mid way so im gonna tig some pins in. Wdut?
Btw nice work looks factory whats the big washer from ?roll the edge on a flat one?
I'm glad I got a couple of the "re-inforced" motomatics while they were available. You can use any of the gy6 50 springs, Malossi's are best. I swapped out the pulley face for a NCY performance one that has better helix angles. In combination with the TJT & Treats plate, variation is flawless.
Thanks big!
> Chris Carleton Wrote:
> Thanks big!
buy this from treats, find a person with a lathe to make the insert to replace the bearings inside and to fit the hobbit input shaft taper, weld it it in.
Done built one just need a belt .I'm guessing a bx41 any ideas?
these are very good, https://www.treatland.tv/honda-hobbit-camino-belt-endurance-p/honda-hobbit-endurance-belt.htm
Nice work.
That stock spring on that pulley is way too strong. Gotta get a horizontal minarelli 2 stroke contra for it.
