Re: Magnum XK Clutch Slip (?) Question
Andrew B /
Hey Ken,
I understand what you are getting at with the stall speeds. My only concern is that I feel like my low-end is crap due to the excessive slipping, and could be better. I also get what you're saying about not having it all with a single speed clutch / motor. I'm just concerned about revving so high off the line and if its in fact a problem. If all is normal and its just the way it is I guess i'll just apply more throttle from a stop.
But for comparison, I have an E50 Maxi with the same carb, intake, filter, similar gearing, Estoril pipe and a stock 3 shoe clutch with kickstart springs and it grabs around 2,800 RPM off the line and runs strong up to about 40mph as well. I just don't know if my issue with my Magnum is clutch related or because the pipe I have has a longer header and hits later in the RPM range or what.
Another update:
Took the OEM 3 shoe clutch with kickstart springs out of my Maxi and put it in the Magnum and gave it a try. Bogs off the line.. Might try putting the blue springs in there tomorrow to see if it will catch / run better off the line without needing to pedal.
