26 is pretty slow. is it a yellow dot?
I would mess with the air filter configuration a bit to make sure you're not missing out on some speed already.
This is the only pipe that pretty much bolts on. You will probably need a longer engine mount bolt and may need to open the hole on the pipe just a hair. It's a pretty good pipe though.
