Re: Best Pipe for top end speed - Garelli SSXL
Dave & Bummerzz /
putting a super revy pipe on a stock cylinder is going to make it worse not better. consider hacking and welding something like a proma gp.
you should also do all the cheap and easy, albeit unsexy, speed enablers such as but not limited to: making sure your brakes aren't rubbing, cleaning carbon from your head, piston and ex port, putting in new rings, cleaning, regreasing and repacking the wheel bearings, setting your timing accurately, cleaning your carb, replacing or at least cleaning and regreasing your chain and of course making sure your tires are properly inflated.
