Electric water pump vs flywheel driven
Dabbling with the idea of a water cooled head.
My bike has 6v but can convert that to 12v easily with around 40w spare.
My gut instinct is telling me electric driven pump save placing more drag on the end of my crankshaft
Re: Electric water pump vs flywheel driven
Electric pump is the way to go. Less chance of failure and also much cheaper too. You can find a nice Bosch aux water pump from a Benz, VW, Audi or BMW at a junk yard for under 20 bucks. The w123 Benz has is right behind the passenger headlight just asking to get ripped out.
Lectric
also the plumbing is way nicer and you can mount them down low where they wont get air bubbles in them.
even if you bleed the whole system it will still get air bubbles in it from outgassing and whatever else so its always best to have the pump be the lowest point in the system
Cool thanks for the tips, I’m looking at a yz250 radd just the one as they run two rads.
Still undecided where to mount it though. Possibly at the rear of the bike or high up behind the headlight/in front of the bars
> they run two rads.
I run a RM 65 radiator on my derbi off to one side. It would be good if you could mount it centered under the gas tank.
> Stephen Simmons Wrote:
> > they run two rads.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F172690137792
Something larger like this would be awesome.
But I think you’re right under the tank would be great I’m just thinking something smaller like this tank might fit
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F400437006429
I air locked my pump badly and it took a good while to figure it out. Short of rearranging the entire system which I eventually did I had to stand the bike up on end to bleed it fully and like you said I eventually caught a bubble again.
This is how mine is set up and I've never had a problem. My pump went out once and it still didn't go over 234° blasting. It doesn't go over 196° while blasting with the pump working. It cruises at 165-180° normal riding depending on temperature outside.
