MK-65 19 dellorto combo
(What causes) temporary high idle at stoplight after full throttle run... I can blip throttle and it goes back to normal idle..... is there an explaination...?
Re: MK-65 19 dellorto combo
sticky throttle grip, sticky throttle cable, sticky slide, or cable end doesnt pop back into its cup.
Not... It is definitely not that... it's in the air/idle jet circuit and I have a 45 idle jet and putting my hand over stack quickly gets it to idle normal again...Thanks for the response...I am hoping someone has had the same issue can explain...
Overpriced Parts /
Use spring loaded float needle maybe,
Could be float level/gas level in bowl, gas puddling, vibration etc.
Idle jet sets higher then main jet in carb bowl,
I did not realize they had spring loaded needle until now. Mine has stiff needle and I already bought a bowl that doesn't hit the mag cover but was trying to get it tuned in before installing it...Puddling sounds like a good reason for the problem too...Thanks...
Baron Von Hamilton /
Could be air fuel mixture screw setting.
You think your idle might be too lean?
Are you getting any crazy spikes in temp?
Lean is what I was thinking too but I think I solved it as the quick change nut on the bowl was still touching the mag cover so I swapped it out with a plain bowl and I guess the vibration was the problem....It's weird what harmonics can do....
Matt Mahloch -- MBM Customs /
My guess is your getting into the next circuit of the carb.
My guess would be air in the idle circuit causing a brief high idle at a stop light.
