Don't forget about the boner.....
This is my second exhaust valve build. Its meant to improve low rpm power with an expansion chamber that is set up for higher rpm performance. It will add to overall pipe volume with a simple 1/4 turn of barrel/spool valve.
Re: Don't forget about the boner.....
More pictures.
Pretty good idea, good job.
You still crazy af?
> You still crazy af?
LMFAO, aren't most of us?......
Hell yes.
Naw Neil was like special crazy.
Like above average
> Stephen Simmons Wrote:
> > You still crazy af?
That's about a quarter of us ......
> Like above average
> > > You still crazy af?
This goes between the cylinder and pipe? Is air chamber getting bolted on the square outlet side?
That's correct. The plan is to insert different lengths of 2 1/2 inch pipe between the two plates seen in the first photo in order to tune it in.
Seems I've seen this 'idea' somewhere before . Maybe Jbot ???
"a quarter of us are above average"
:P
Dirty30 Dillon /
Stop metalworking in fleece pajamas and thong sandals, it's 2019
yeah weld in crocs like a real man.
how bout you stop checking out other dudes outfits.
What are you wearing alex?
Oooohhhhhhh shit is fire haha
right now iam in my shop overall. at home iam in shorts and flip flops. sometimes I free ball.
Dirty30 Dillon /
x2, a/s/l
> Dirty30 Dillon Wrote:
> x2, a/s/l
lmao... i haven't been asked that for awhile. you took it back to AIM with that one.
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
It looks like u damn near built a power valve.
Hack out some slides like this,
Spring and cable like a carb, jam it in that wallered out hole and stuff.
Guaranteed mabe!
Who said power valve gotta be ah slide to be considered a "POWER VAVLE"......, the "boner" I was so fond of was only missing a reasonable valve ..., i Donna dreamt slide valve ...., it ain't reasonable in the , buy it, and bolt it together world I'm in , it ain't gonna happen without too much fanfare for me.... The slide is a great style valve though....! Oh, by the way...., by all reasonable definition, this is a power valve.
Screwed that one up..., it isn't no power valve. Go ahead ,now there's a reason ta shoot me....
ATAC
One boner at a time.
I suppose if I had been nay-kee wearing raeh-za sharp cuttings, you'd grasp upon something else to gripe about? Did you see the first cutting tool. Any how, I post and some bitch.
Dirty30 Dillon /
You seem really relaxed and easy going.
I am not crazy. Everyone else is. Can't you see?
Here is the first valve build. It was cast in aluminum. It worked really well but the spool was crappy and the whole thing could have been smaller and weighed less. It looked cool though considering it hugged the cylinder.
♣Slew Foot♣ /
Now I'm just curious about this what is the purpose of adjusting the flow? Is it about restriction because you could just make a stack and have a weighted lid or an adjustable tension spring what is the real purpose I mean? Can you automatically adjust the shape of the chambers of the sound wave is bouncing a certain way back up the cylinder are you creating some kind of vortex I mean if it's not restricted and you have reeds you just have to have the right shape chamber to have good low-end and then the high end is just a matter of no restriction and the shape of the chamber to start with I got an 80cc aircraft exhaust no restriction it just had some straight pipes in the way of the sound waves it was quiet and it ripped
