Re: 1989 Yamaha DT50 build thread
Nick Haber /
> J D Wrote:
> Dude, that is a loooot of corrosion. Like mopedallday said, your carb
> is toast. In addition the the chem neutralization with evaporust,
> you're going to need to mechanically remove the debris. Put some bolts
> and nuts in the tank and shake all that crap loose so you can flush it
> out.
> I'd be interested to see closer pics of the fairings and body. Is there
> any rot in the plastics or frame?
> Regarding the piston being seized, WD40 might not cut it. PB plaster or
> another heavy duty penetrating/creeping oil might help. WD is more for
> water displacement (ergo "WD") and cleaning but it does a lot of stuff
> well enough. Best luck I've ever had was using diesel fuel (old dodge
> truck motor) but it took a loooong time. Also steel and cast iron so
> the chemistry might be different.
> Good Luck!!!! Interested to see how this developes for you.
Yeah the cylinder has been soaking in PB blaster since I got it. I did shake up the tank with some nuts and bolts in it when I first got it, and I got out a concerning amount of rust. Then I flushed it with water/air/evaporust and now gas. But I mean it still holds liquid so I guess I'm good. I am probably going to have to purchase a new carb, which is gonna be like $125 unless I can find someone on here with one. Thanks!
  1989 Yamaha DT50 build threadTopic by: Nick Haber Nick Haber 07/04/19 12:52AM
  Re: 1989 Yamaha DT50 build threadRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 07/04/19 12:57AM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 07/04/19 01:08AM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 07/04/19 01:01AM
  Re: 1989 Yamaha DT50 build threadRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 07/04/19 08:42AM
  Re: 1989 Yamaha DT50 build threadRe: Alex hernandez Alex hernandez 07/04/19 10:05AM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 07/04/19 12:44PM
  Re: 1989 Yamaha DT50 build threadRe: Daniel '' Daniel '' 07/05/19 06:24PM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 07/05/19 08:27PM
  Re: 1989 Yamaha DT50 build threadRe: Dirty30 Dillon Dirty30 Dillon 07/07/19 10:28AM
  Re: 1989 Yamaha DT50 build threadRe: P D P D 07/07/19 11:48AM
  Re: 1989 Yamaha DT50 build threadRe: Daniel '' Daniel '' 07/07/19 12:44PM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 07/07/19 11:04PM
  Re: 1989 Yamaha DT50 build threadRe: Graham Motzing Graham Motzing 07/08/19 10:20AM
  Re: 1989 Yamaha DT50 build threadRe: J D J D 07/05/19 04:10AM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 07/05/19 11:00AM
  Re: 1989 Yamaha DT50 build threadRe: P D P D 07/05/19 11:11AM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 07/05/19 11:50AM
  Re: 1989 Yamaha DT50 build threadRe: Blake MD No PM Plz Blake MD No PM Plz 07/05/19 11:55AM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 07/05/19 08:33PM
  Re: 1989 Yamaha DT50 build threadRe: Chris Szuba Chris Szuba 07/17/19 01:47PM
  Re: 1989 Yamaha DT50 build threadRe: Zach Riddle Zach Riddle 07/26/19 01:14PM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 07/26/19 01:21PM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 08/25/19 05:39PM
  Re: 1989 Yamaha DT50 build threadRe: Daniel '' Daniel '' 08/25/19 06:41PM
  Re: 1989 Yamaha DT50 build threadRe: Zach Riddle Zach Riddle 08/25/19 06:45PM
  Re: 1989 Yamaha DT50 build threadRe: Daniel '' Daniel '' 08/25/19 09:57PM
  Re: 1989 Yamaha DT50 build threadRe: Zach Riddle Zach Riddle 07/26/19 01:26PM
  Re: 1989 Yamaha DT50 build threadRe: Mr Chubbins Mr Chubbins 09/08/19 06:57PM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 09/08/19 09:47PM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 01/12/20 03:48PM
  Re: 1989 Yamaha DT50 build threadRe: P D P D 01/12/20 04:42PM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 01/12/20 04:52PM
  Re: 1989 Yamaha DT50 build threadRe: P D P D 01/12/20 05:06PM
  Re: 1989 Yamaha DT50 build threadRe: Daniel '' Daniel '' 01/12/20 05:31PM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 01/12/20 06:33PM
  Re: 1989 Yamaha DT50 build threadRe: Daniel '' Daniel '' 01/12/20 07:05PM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 03/19/20 03:53PM
  Re: 1989 Yamaha DT50 build threadRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/19/20 05:38PM
  Re: 1989 Yamaha DT50 build threadRe: Graham Motzing Graham Motzing 03/20/20 01:00PM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 03/20/20 01:49PM
  Re: 1989 Yamaha DT50 build threadRe: Graham Motzing Graham Motzing 03/20/20 05:44PM
  Re: 1989 Yamaha DT50 build threadRe: Nick Haber Nick Haber 03/20/20 09:26PM
  Re: 1989 Yamaha DT50 build threadRe: river 2strokes river 2strokes 01/14/20 12:51PM
