been working on a dt50 at work, found out the ysr50 piston is the same. ysr50 and dt50 share the same connecting rod. Wiesco stocks them got a 1.0 over bore. sent cylinder for bore and hone. going to plug oil injection, most likely carb swap. another interesting thing the coolent sensor is the same as a vino 2012 and up i believe.
