> Zach Riddle Wrote:
> been working on a dt50 at work, found out the ysr50 piston is the same.
> ysr50 and dt50 share the same connecting rod. Wiesco stocks them got a
> 1.0 over bore. sent cylinder for bore and hone. going to plug oil
> injection, most likely carb swap. another interesting thing the coolent
> sensor is the same as a vino 2012 and up i believe.
I wound up buying another stock carb off eBay. My plan is to get it running as close to stock as possible, then start modding to document the actual performance gains. I think I'm gonna buy an HPI ignition before I buy a kit for the top end or anything.
It's my understanding that the YSR50 engine is almost identical to the DT50LC. Dos cycles also carries pistons/rings for these bikes
