Re: 1989 Yamaha DT50 build thread
Nick MBC /
> Graham Motzing Wrote:
> anything with actual break-through pin holes, the easiest way to fix it
> is brazing it. sealers won't hold once its broke through no matter what
> i dunno i avoid all that shit, i do a muriatic acid soak using a
> rubbermaid with like 1" in the bottom to really burn it all out good,
> then i strip the paint in the affected area, then a couple rinses, then
> braze it, coat the inside with half gas half oil mix, sand, bondo, sand,
> primer, paint.
> i've saved some pretty gnarly shit. This ninja 250 had like 1/4" rust
> holes that i had to weld roofing nails to close up, someone had tried a
> bad JB weld and bondo job on it and it was all smashed up. When i was
> done you could definitely tell it had been patched, but it didn't leak
> and got the jerb done. More time with the bondo and i could have made
> it nice but it was a $200 commuter/beater bike so who cares.
That's inspiring! The only reason I used the Kreem instead of brazing in the first place is that a friend got a random package with a bunch of motorcycle shit in it (clutch levers, motocross boots, Kreem, etc.) that he didn't order and so he gave it to me.
It's my understanding that the only good way to get gas resistance when repainting a tank is to powdercoat it; is that the case? I've never painted a tank before
  1989 Yamaha DT50 build threadTopic by: Nick MBC Nick MBC 07/04/19 12:52AM
  Re: 1989 Yamaha DT50 build threadRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 07/04/19 12:57AM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 07/04/19 01:08AM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 07/04/19 01:01AM
  Re: 1989 Yamaha DT50 build threadRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 07/04/19 08:42AM
  Re: 1989 Yamaha DT50 build threadRe: Alex hernandez Alex hernandez 07/04/19 10:05AM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 07/04/19 12:44PM
  Re: 1989 Yamaha DT50 build threadRe: Daniel '' Daniel '' 07/05/19 06:24PM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 07/05/19 08:27PM
  Re: 1989 Yamaha DT50 build threadRe: Dirty30 Dillon Dirty30 Dillon 07/07/19 10:28AM
  Re: 1989 Yamaha DT50 build threadRe: P D P D 07/07/19 11:48AM
  Re: 1989 Yamaha DT50 build threadRe: Daniel '' Daniel '' 07/07/19 12:44PM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 07/07/19 11:04PM
  Re: 1989 Yamaha DT50 build threadRe: Graham Motzing Graham Motzing 07/08/19 10:20AM
  Re: 1989 Yamaha DT50 build threadRe: J D J D 07/05/19 04:10AM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 07/05/19 11:00AM
  Re: 1989 Yamaha DT50 build threadRe: P D P D 07/05/19 11:11AM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 07/05/19 11:50AM
  Re: 1989 Yamaha DT50 build threadRe: Blake MD No PM Plz Blake MD No PM Plz 07/05/19 11:55AM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 07/05/19 08:33PM
  Re: 1989 Yamaha DT50 build threadRe: Chris Szuba Chris Szuba 07/17/19 01:47PM
  Re: 1989 Yamaha DT50 build threadRe: Zach Riddle Zach Riddle 07/26/19 01:14PM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 07/26/19 01:21PM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 08/25/19 05:39PM
  Re: 1989 Yamaha DT50 build threadRe: Daniel '' Daniel '' 08/25/19 06:41PM
  Re: 1989 Yamaha DT50 build threadRe: Zach Riddle Zach Riddle 08/25/19 06:45PM
  Re: 1989 Yamaha DT50 build threadRe: Daniel '' Daniel '' 08/25/19 09:57PM
  Re: 1989 Yamaha DT50 build threadRe: Zach Riddle Zach Riddle 07/26/19 01:26PM
  Re: 1989 Yamaha DT50 build threadRe: Mr Chubbins Mr Chubbins 09/08/19 06:57PM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 09/08/19 09:47PM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 01/12/20 03:48PM
  Re: 1989 Yamaha DT50 build threadRe: P D P D 01/12/20 04:42PM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 01/12/20 04:52PM
  Re: 1989 Yamaha DT50 build threadRe: P D P D 01/12/20 05:06PM
  Re: 1989 Yamaha DT50 build threadRe: Daniel '' Daniel '' 01/12/20 05:31PM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 01/12/20 06:33PM
  Re: 1989 Yamaha DT50 build threadRe: Daniel '' Daniel '' 01/12/20 07:05PM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 03/19/20 03:53PM
  Re: 1989 Yamaha DT50 build threadRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/19/20 05:38PM
  Re: 1989 Yamaha DT50 build threadRe: Graham Motzing Graham Motzing 03/20/20 01:00PM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 03/20/20 01:49PM
  Re: 1989 Yamaha DT50 build threadRe: Graham Motzing Graham Motzing 03/20/20 05:44PM
  Re: 1989 Yamaha DT50 build threadRe: Nick MBC Nick MBC 03/20/20 09:26PM
  Re: 1989 Yamaha DT50 build threadRe: river 2strokes river 2strokes 01/14/20 12:51PM
