Disc break caliper placement.
Wolf Wizard /
So maybe a dumb question, but I've never had to custom mount a caliper before. Are there specs to how far away the rotor should sit, or how much clearance between the rotor and the pads? The gap between the pads almost seems too small, but I was told the gold caliper from treats was great for the cr80 rotor (cr80 rotor mated to this k100 wheel via a machined spacer. The wheel came with no rotor and they are hella expensive, and had this cr80 one around for a while.)
It fits in the nook super well and seems like I can make it work with some custom mounting tabs, but no matter where I hold it, and this might be me being a human who obviously cannot hold something perfectly still, cannot spin the wheel with the rotor there without constantly hearing a very slight rubbing of the pads on the rotor, which leads me to my secondary question. is that normal and does that noise go away when the pads "break in" some?
Any help much appreciated, plan on doing en entire write up on this swap when it's done.
  Disc break caliper placement.Topic by: Wolf Wizard Wolf Wizard 08/02/19 12:28AM
  Re: Disc break caliper placement.Re: Baron Von Moped Baron Von Moped 08/02/19 12:52AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 01:06AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 01:53AM
  Re: Disc break caliper placement.Re: live ɘvil live ɘvil 08/02/19 10:38AM
  Re: Disc break caliper placement.Re: Dirty30 Dillon Dirty30 Dillon 08/02/19 10:57AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 11:19AM
  Re: Disc break caliper placement.Re: Dirty30 Dillon Dirty30 Dillon 08/02/19 11:26AM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 01:09PM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 01:25PM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 01:34PM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 01:49PM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 01:08AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 02:50PM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 02:56PM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 01:43AM
  Re: Disc break caliper placement.Re: live ɘvil live ɘvil 08/14/19 03:52AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 04:48AM
  Re: Disc break caliper placement.Re: Dave & Bummerzz Dave & Bummerzz 08/14/19 09:35AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 11:03AM
  Re: Disc break caliper placement.Re: Mikey Antonakakis Mikey Antonakakis 08/14/19 12:22PM
  Re: Disc break caliper placement.Re: Michael Thomas Michael Thomas 09/10/19 11:58AM
  Re: Disc break caliper placement.Re: Mikey Antonakakis Mikey Antonakakis 09/10/19 01:02PM
  Re: Disc break caliper placement.Re: Charlie BUZZARD Charlie BUZZARD 09/11/19 09:18AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 09/17/19 02:15AM
  Re: Disc break caliper placement.Re: Born to be WillD Born to be WillD 09/18/19 07:26PM
  Re: Disc break caliper placement.Re: Born to be WillD Born to be WillD 09/18/19 07:28PM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 09/22/19 01:49AM
