Re: Disc break caliper placement.
Wolf Wizard /
so what i did was sat the caliper in the nook ontop the rotor so that it was laying on it flush. i then gently lifted one end, and put a piece of 18g wire on the edge of the rotor and set the caliper back down, holding it in place, then did the same to the other side. now the caliper height wise should be "hovering" that same distance the whole way around. I then marked where the two mounting holes will generally be on that old shock mount. i think this should get this "hover" very close. Moped close.
I think the net step is to grind away where i want the mounting holes to be and but some 8mm ID spacers, I'll then weld these in flush with the back of the shock mount (using a plate) so that the rotor does not sit cooked. And shim the left to right accordingly to get it so that jussssst done touch the static pad that does not move.
Should be able to get it done in a week or so.
  Disc break caliper placement.Topic by: Wolf Wizard Wolf Wizard 08/02/19 12:28AM
  Re: Disc break caliper placement.Re: Baron Von Moped Baron Von Moped 08/02/19 12:52AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 01:06AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 01:53AM
  Re: Disc break caliper placement.Re: live ɘvil live ɘvil 08/02/19 10:38AM
  Re: Disc break caliper placement.Re: Dirty30 Dillon Dirty30 Dillon 08/02/19 10:57AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 11:19AM
  Re: Disc break caliper placement.Re: Dirty30 Dillon Dirty30 Dillon 08/02/19 11:26AM
  Re: Disc break caliper placement.Re: Master D. Baiter Master D. Baiter 08/02/19 01:09PM
  Re: Disc break caliper placement.Re: Master D. Baiter Master D. Baiter 08/02/19 01:25PM
  Re: Disc break caliper placement.Re: Master D. Baiter Master D. Baiter 08/02/19 01:34PM
  Re: Disc break caliper placement.Re: Master D. Baiter Master D. Baiter 08/02/19 01:49PM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 01:08AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 02:50PM
  Re: Disc break caliper placement.Re: Master D. Baiter Master D. Baiter 08/02/19 02:56PM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 01:43AM
  Re: Disc break caliper placement.Re: live ɘvil live ɘvil 08/14/19 03:52AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 04:48AM
  Re: Disc break caliper placement.Re: Dave & Bummerzz Dave & Bummerzz 08/14/19 09:35AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 11:03AM
  Re: Disc break caliper placement.Re: Mikey Antonakakis Mikey Antonakakis 08/14/19 12:22PM
  Re: Disc break caliper placement.Re: Michael Thomas Michael Thomas 09/10/19 11:58AM
  Re: Disc break caliper placement.Re: Mikey Antonakakis Mikey Antonakakis 09/10/19 01:02PM
  Re: Disc break caliper placement.Re: Charlie BUZZARD Charlie BUZZARD 09/11/19 09:18AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 09/17/19 02:15AM
  Re: Disc break caliper placement.Re: Born to be WillD Born to be WillD 09/18/19 07:26PM
  Re: Disc break caliper placement.Re: Born to be WillD Born to be WillD 09/18/19 07:28PM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 09/22/19 01:49AM
