Re: Disc break caliper placement.
Dave & Bummerzz /
The pad to rotor clearance on hydraulic calipers set themselves once you've bled them and squeezed the master cylinder, that's the beauty of them vs. mech calipers. Clamping a spacer between them when bleeding won't set the clearance that only works on mech calipers. It won't rub, and if it does that means one of the pistons is sticking which you can usually fix with a little penetrating oil and a c clamp.
for mounting, you want to set up and bleed a brake system then clamp the caliper onto the rotor so that the rotor has a few mm of clearance between the bottom of the caliper. when the caliper is in the desired position use that to create your brackets.
  Disc break caliper placement.Topic by: Wolf Wizard Wolf Wizard 08/02/19 12:28AM
  Re: Disc break caliper placement.Re: Baron Von Moped Baron Von Moped 08/02/19 12:52AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 01:06AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 01:53AM
  Re: Disc break caliper placement.Re: live ɘvil live ɘvil 08/02/19 10:38AM
  Re: Disc break caliper placement.Re: Dirty30 Dillon Dirty30 Dillon 08/02/19 10:57AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 11:19AM
  Re: Disc break caliper placement.Re: Dirty30 Dillon Dirty30 Dillon 08/02/19 11:26AM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 01:09PM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 01:25PM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 01:34PM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 01:49PM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 01:08AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/02/19 02:50PM
  Re: Disc break caliper placement.Re: Ada Dictome Ada Dictome 08/02/19 02:56PM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 01:43AM
  Re: Disc break caliper placement.Re: live ɘvil live ɘvil 08/14/19 03:52AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 04:48AM
  Re: Disc break caliper placement.Re: Dave & Bummerzz Dave & Bummerzz 08/14/19 09:35AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 08/14/19 11:03AM
  Re: Disc break caliper placement.Re: Mikey Antonakakis Mikey Antonakakis 08/14/19 12:22PM
  Re: Disc break caliper placement.Re: Michael Thomas Michael Thomas 09/10/19 11:58AM
  Re: Disc break caliper placement.Re: Mikey Antonakakis Mikey Antonakakis 09/10/19 01:02PM
  Re: Disc break caliper placement.Re: Charlie BUZZARD Charlie BUZZARD 09/11/19 09:18AM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 09/17/19 02:15AM
  Re: Disc break caliper placement.Re: Born to be WillD Born to be WillD 09/18/19 07:26PM
  Re: Disc break caliper placement.Re: Born to be WillD Born to be WillD 09/18/19 07:28PM
  Re: Disc break caliper placement.Re: Wolf Wizard Wolf Wizard 09/22/19 01:49AM
