Botanas 70cc MB5 Kit
anyone running this?
https://www.doscycles.com/products/honda-mb5-botanas-racing-45mm-70cc-cylinder-kit?variant=8123855175782
guessing it's similar to the treats import kit?
Any tips, tricks, reviews?
Going to be running it with a vm20 and starting off with a 150 jet and working my way down. Is that a good starting point?
Re: Botanas 70cc MB5 Kit
Womp womp
I have that, its solid. I mostly got it cuz it gives a lil boost to torque. Like it's almost no faster top speed but you don't have to ride the clutch and keep the revs so high.
As for tips, the hpi woke it the fuck up. I got an ns carb and couldn't begin to guess the jet, I wanna say its bigger than 150 but 150 is probably a good start, mikuni is less steep a jump between jet sizes once they get bigger #s (numbered by flow vs diameter scales linear vs squared)
awesome thanks for the reply. i was hoping it would give me a torque boost. I'm ok with my current top speed of ~50.
I started installing it yesterday, think i might need an intake riser for the MB5 carb, or might just bite the bullet and by an MLM intake.
I'm not okay with 50, I want at the very least a usable 55. I'm using a stock cylinder with a home made pipe and a 19mm OKO. I recently went up to a 15 tooth front sprocket and hit 54 but it didn't want to wind out to get there. Struggling to pull it in 5th really. This kit could be the answer to more top end after re-gearing?
I'm gonna give it a shot... Stay tuned.
My kitted MB5 does 55, but I run a 12 or 13 up front? I cant remember which off the top of my head, but it gives me mad torque, could go much faster though if thats what your going for
I mean you already have the kit so why not put it on?
Wait... holy shit... I FORGOT!!
LMFAO!!!!! I figured you did......
Found it... I will report back. I did 57 tonight on the stocker. It needs road to do it, but it got there.
Looks like it could use some dremel work.
I had a MB5 that I built back in 2007 that had this 70cc polini kit , HPI, boysen reeds, 21phbg, homoet pipe and a 14 or 15 in front that would cruise at 65 in 5th. I sold it to Ryan Nash in 2010, not sure where it ended up.
so getting the piston in was a mother fucker. not sure if the rings were too big or what.
sanded the ends and i eventually got it on. paired with 70cc head and a vm20 it runs like shit.
running a 150 jet, i think that my plug might actually be super fouled so i'll replace and update.
> too big or what. sanded the ends and i eventually got it on.
Did you size the ring gap before installation ?
> I had a MB5 that I built back in 2007 that had this 70cc polini kit,
> where it ended up.
I did the same with a 6-speed trans, it was soooo fast, but with a Homeot it was pretty miserable to ride (imo), you had to keep it at 9500 RPM or it didnt make power, just a lot of shifting, but fast as all get out
> too big or what.
Nahhh dude your lean as hell, if your running the stock CDI and a pipe start at like 180
so one year later i'm playing with this again. I deleted the oil pump and installed the blockoff plate that i had kicking around. Also fixed the leaky gas tank (hopefully 3rd times the charm). Only runs with choke on and revs to the moon....air leak?
Well I'm dumb. Turns out the reason it was revving to the moon is that the throttle cable was hung up and had the carb 3/4 open. Also, the reason it would die immediately on throttle is because of the stupidly small jet. I initially had a 150, then went down to 135 after some posts I read. I guess they were talking about 50cc because it runs perfectly after a 180 jet. (vm20)
Dirty30 Dillon /
I've never put a completely off-the-shelf VM20 on a bike and not had it run immediately with the 180. The fine tuning will go up and down, but literally 5/5 bikes I've run them on just start and ride with the 180 in them.
Yeah, i guess they sell it with a 180 for a reason. I have the entire range of jets and a tons of needles so def some fine tuning after some plug chops/temp monitoring. For now though she's roadworthy....or at least enough to get me to the liquor store and back.
Iā€™m dying šŸ¤£
Yeah I'm running a vm20 on my mb5 with a stock cylinder, MLM pipe, screen air filter, and I'm running a 165 main jet. Kinda feel like I could go 170 ...
Just dropped in the 170 jet and its alot peppier. Plug chops look good.
What are you topping out at?
GPS'd 55 mph. gets there pretty quick as well.
I still have to slip the clutch to get any sort of low end but it pulls really hard.
Think i have a 25 idle jet and a 165 main in the vm20.
Dirty30 Dillon /
But wait: stock mb5's do 50mph...
yes they do, but it takes forever to get there.
This provides way more torque and gets me there super quick.
I run this kit now on all mbs, I've done the airsal, Parma and malossi and I prefer this one the most. Take the bridge out of the intake and match the piston, my chopper mb does 56 geared 14/42 with just Reed's a really dumb pipe anda phbg21, my faster mb always does 65 geared 12/36. It's a great kit
You chop a hole in the piston? Looking at the kit before i put it on i wondered why the piston wasn't windowed.
« Go to Topics ā€” end of thread
