that’s boost ports :)
Going to run the stock 16mm carb , but i cut the rotory valve to the yam GYT specs for racing . and bored the in take out to 19mm . can also move up to the big 22mm carb if i need be .. just have to fit a 22mm intake tube :)
Want a stock look so running a sock pipe .. so really big carb maybe waist
