well ,,, need a stock throttle grip and other rubber bits .
but it’s running good ..
Took the dam tick over screw stop out and will adjust the tick over with the cable adjuster.
it’s 3 mm wide 12 mm long and 5 mm on the end in the dam air flow ??
Must be 10% or more of the flow blocked.
