Don’t use that pipe get a circuit type pipe and a hi flow air filter. Rebuilding is a good idea with needle bearing crank because you really need to take the motor apart to case match the kit. Keep the gearing under 10k rpm.
Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tips
