Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tips
Overpriced Parts /
> Rocco Taco Wrote:
> That kit makes a lot of power!
> I would not run a lil bing for the kit.
With a 14mm bing (I like it better then 15mm on pp kits) and knowing to tune I keep up with 19 and 21 mm phbg carbs (if he is talking about a piston port cylinder) as well as killing big carb off the line with same pipe and stock ignition, the 17.5 dellorto phva is the exception (that carb rules) it has good low end if he’s talking about reed kit then ya bigger carburetor is better,
Getting back to the OP’s questions you got a mismatch set up, with a high rpm pipe and stock gearing you are going to have to rebuild with a needle bearing crank plus you’ll be running way hotter at speed so you may need aftermarket auto retard ignition to run cooler at speed, if you could keep your RPMs lower (14mm bing, circuit or estoril pipe and up gear you could run stock ignition and stock crank,
Blue springs are nothing, you need to get stiffy kickstart springs,
Don’t do any porting until your kit is tuned and broken in and you are able to run cool on long runs,
The more porting you do the more metal you remove so the more heat sink capabilities you remove unless you carve gas porting channels and other fancy stuff with a dental drill
Also if you’re using stock ignition make sure you completely service your magneto and learn timing, the information is here https://www.mopedarmy.com/wiki/Puch_timing
I had a friend revise it a little while ago so it has more and better information on the care and feeding of stock ignition
  Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsTopic by: Joshua Rosa Joshua Rosa 08/11/19 03:27AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Sir Clip Sir Clip 08/11/19 07:06AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: * * * * 08/12/19 11:59PM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Overpriced Parts Overpriced Parts 08/27/19 11:50PM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: * * * * 08/28/19 12:50AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Overpriced Parts Overpriced Parts 08/28/19 01:40AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Tweaker trash Tweaker trash 03/30/20 06:05AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Joshua Rosa Joshua Rosa 08/28/19 02:18AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Joshua Rosa Joshua Rosa 08/28/19 02:23AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Adam Smith Adam Smith 08/28/19 05:08AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Adam Smith Adam Smith 08/28/19 05:10AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Joshua Rosa Joshua Rosa 08/28/19 05:55AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Adam Smith Adam Smith 08/28/19 06:31AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Adam Smith Adam Smith 08/13/19 05:56AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Aaron Blair Aaron Blair 08/13/19 07:41AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Joshua Rosa Joshua Rosa 08/27/19 09:53PM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Joshua Rosa Joshua Rosa 08/27/19 09:56PM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Adam Smith Adam Smith 08/28/19 06:33AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Thomas Peffer Thomas Peffer 03/21/20 09:38PM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Adam Smith Adam Smith 03/27/20 07:05PM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Christian James Christian James 03/29/20 11:17AM
  Re: Bought a 70cc45mm Dmp kit for my E50 pinto puch . helpful tipsRe: Jeff Parr Jeff Parr 03/29/20 06:23PM
