> Rocco Taco Wrote:
> > Overpriced Parts Wrote:
> > > Rocco Taco Wrote:
> > > That kit makes a lot of power!
> > > I would not run a lil bing for the kit.
> > With a 14mm bing (I like it better then 15mm on pp kits) and knowing
> to
> > o tune I keep up with 19 and 21 mm phbg carbs (if he is talking about
> a
> > piston port cylinder) as well as killing big carb off the line with
> same
> > pipe and stock ignition, the 17.5 dellorto phva is the exception (that
> > carb rules) it has good low end if he’s talking about reed kit then
> ya
> > bigger carburetor is better,
> Your dmp kit with a 14mm bing goes 58mph+?
You didn’t read what I said, “if he was talking about a dmp reed valve kit I said a bigger carburetor is better” but not a dmp piston port kit (a 70cc dmp pp kit like a 70cc kstar/treats kit but better) which I was talking about, he didn’t say dmp reed kit
And ya I hit 58mp but with a smaller 64cc 43mm reed kit and 15mm bing not 14mm Running stock ignition and stock crank/stock bottom end,
Built In 2006-07 and still maintained it still goes as fast, runs cool as a cucumber and still hasn’t blown up, built for a fraction of money, parts and time you got in your bike, I take it anywhere,
