> Overpriced Parts Wrote:
> > > > Rocco Taco Wrote:
> > > > That kit makes a lot of power!
> > > > I would not run a lil bing for the kit.
> > > With a 14mm bing (I like it better then 15mm on pp kits) and knowing
> > to
> > > o tune I keep up with 19 and 21 mm phbg carbs (if he is talking
> about
> > a
> > > piston port cylinder) as well as killing big carb off the line with
> > same
> > > pipe and stock ignition, the 17.5 dellorto phva is the exception
> (that
> > > carb rules) it has good low end if he’s talking about reed kit then
> > ya
> > > bigger carburetor is better,
> > Your dmp kit with a 14mm bing goes 58mph+?
> You didn’t read what I said, “if he was talking about a dmp reed valve
> e kit I said a bigger carburetor is better” but not a dmp piston port
> kit (a 70cc dmp pp kit like a 70cc kstar/treats kit but better) which I
> was talking about, he didn’t say dmp reed kit
> And ya I hit 58mp but with a smaller 64cc 43mm reed kit and 15mm bing
> not 14mm Running stock ignition and stock crank/stock bottom end,
> Built In 2006-07 and still maintained it still goes as fast, runs cool
> as a cucumber and still hasn’t blown up, built for a fraction of money,
> parts and time you got in your bike, I take it anywhere,
Thats mad blurry and shaky and those cables are not accurate all the time. Make a video with a gps and hd quality camera!
