Re: Just got a Puch - do I need to upjet with a new pipe?
Overpriced Parts /
Unless you get a performance/mesh type filter you’ll never get that sucker tuned for good gains and crisp clean jetting through the range (air in air out) with the stock square plastic, turbulence, restrictive causing junk air box.
Make sure your magneto is serviced and your points cleaned and gapped, cam lobe on flywheel lubed and timing set to specifications because you need correct timing first before you start tuning,
