Re: PW65 Malossi with WWB ceramic bearings
Graham Motzing /
> mat hormell Wrote:
> I have looked at
> some of the qt pipes but they are just so damn massive lol.
yeah the best pipes for this application don't get made for QT's, either a good scooter pipe like a leovince or an MLM or Crank pipe all designed for puchs are your best bet. The scooter pipes and stuff like doppler and giannelli for variated bikes might not have the grunt to get you rolling depending on how your clutch tuning works out.
i haven't worked with that malossi kit in years, i put one on a hobbit once... and that is assuming its the same porting as the hobbit which i think it is.... it was overwhelmingly meh. i'm not even sure if it will make enough power to light up a big pipe. Unfortunately that is going to be the weak link... like putting 2" primary headers and a 850 holly on a high rise on a smal block chevy but then putting a stock cam in it.
unless you are planning on some kinda wizard porting using dental tools and stuff, that is really going to throw off the build. Maybe a tomos tecno estoril? those perform well on lower output cylinders. At some point you cant raise the exhaust anymore because you'll have too much blowdown and the transfers won't be big enough to keep it from stalling.
If i were you i'd weld up the cases and adapt right away for a scooter cylinder with good aftermarket support like a minarelli horizontal or something (if the stroke comes out close, which i think it does, you can fudge it with porting and the thickness of the spacer) then start with a conservative either 70cc or 50cc mildly ported cylinder, which you can swap later for an aggressively ported full race cylinder. There is also a lot of H20 cylinders for those platforms, but for drag racing you shouldn't need fan cooling or anything. Worst case scenario you can put a electric fan on it or run a leaf blower on it in the pits. just seems like trying to make this whole build work around a really crummy cylinder just because that is the only one out there, really limits the potential.
  PW65 Malossi with WWB ceramic bearingsTopic by: mat hormell mat hormell 08/14/19 05:59PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: P D P D 08/14/19 06:11PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/14/19 06:16PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/14/19 06:17PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/14/19 06:19PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/14/19 06:18PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Jack Rutherford Jack Rutherford 08/15/19 09:24AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/15/19 10:41PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Dave & Bummerzz Dave & Bummerzz 08/15/19 10:03AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/15/19 10:46PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 09:17PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Dave & Bummerzz Dave & Bummerzz 08/16/19 10:08PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: alex . alex . 08/15/19 07:49PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/15/19 10:48PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/16/19 01:23AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 12:44PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 12:54PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 12:59PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/16/19 03:23PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 07:57PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/16/19 03:41PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 05:22PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 07:22PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/16/19 06:26PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 09:00PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 09:12PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/17/19 12:15PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/17/19 07:38PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/18/19 01:08AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: live ɘvil live ɘvil 08/21/19 09:42AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 03:32PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/21/19 08:13AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/21/19 08:17AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 04:01PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 04:10PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: live ɘvil live ɘvil 08/21/19 04:38PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 04:55PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: live ɘvil live ɘvil 08/21/19 06:37PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 06:57PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: live ɘvil live ɘvil 08/21/19 07:39PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 02:15PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 02:20PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 02:17PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 03:10PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/22/19 05:34PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 05:58PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Dave & Bummerzz Dave & Bummerzz 08/23/19 09:25AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 10:47AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 11:16AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 12:03PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/23/19 02:11PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 02:57PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/23/19 11:56AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 12:16PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 12:30PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 01:40PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 12:22PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 12:49PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 03:12PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/23/19 03:15PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 03:09PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 03:14PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 04:42PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Daniel '' Daniel '' 08/23/19 08:32PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 08:36PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Daniel '' Daniel '' 08/23/19 09:12PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 09:15PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Daniel '' Daniel '' 08/23/19 09:40PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/25/19 12:38PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Daniel '' Daniel '' 08/25/19 02:44PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/25/19 06:55PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 03:20PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 03:22PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 06:59PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/26/19 12:52PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/26/19 02:39PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/26/19 02:44PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/26/19 03:02PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/26/19 06:21PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 08:38PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 09:23PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/25/19 01:43PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/27/19 12:04AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/27/19 12:08AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: P D P D 08/27/19 09:49AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/27/19 01:02PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/27/19 10:09AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/27/19 12:09PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/27/19 01:03PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/28/19 03:59PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 03/06/20 12:46PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/28/19 04:05PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/28/19 11:48PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Jack Rutherford Jack Rutherford 08/29/19 08:48AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/29/19 10:57AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/29/19 12:19PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/29/19 12:33PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/29/19 04:24PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/30/19 01:07PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/30/19 03:37PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/29/19 09:42PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 03/05/20 07:39PM
