Re: PW65 Malossi with WWB ceramic bearings
Mikey Antonakakis /
Like Graham said, transfers are kinda the limiting factor for making good power on a lot of off-the-shelf kits. From the kits I've seen, at least, usually there is enough exhaust port (and they are generally easy enough to increase exhaust duration) to make power, but it's a major job to get the transfers to keep up. I have no idea how well the bolt pattern and deck height and whatnot would match up, but the Peugeot Eurokit you can get at Treatland for $100 has the highest-duration transfers I've seen, 130deg out of the box, meaning you wouldn't really need to touch them.
Is this the kit you're using? https://www.treatland.tv/yamaha-QT50-YT60-malossi-70cc-kit-p/malossi-qt50-kit-318007.htm
If so, it looks like it may have some potential, at least for a lot more than 4.5hp. Post a port map if/when you can.
  PW65 Malossi with WWB ceramic bearingsTopic by: mat hormell mat hormell 08/14/19 05:59PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: P D P D 08/14/19 06:11PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/14/19 06:16PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/14/19 06:17PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/14/19 06:19PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/14/19 06:18PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Jack Rutherford Jack Rutherford 08/15/19 09:24AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/15/19 10:41PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Dave & Bummerzz Dave & Bummerzz 08/15/19 10:03AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/15/19 10:46PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 09:17PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Dave & Bummerzz Dave & Bummerzz 08/16/19 10:08PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: alex . alex . 08/15/19 07:49PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/15/19 10:48PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/16/19 01:23AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 12:44PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 12:54PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 12:59PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/16/19 03:23PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 07:57PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/16/19 03:41PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 05:22PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 07:22PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/16/19 06:26PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 09:00PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 09:12PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/17/19 12:15PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/17/19 07:38PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/18/19 01:08AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: live ɘvil live ɘvil 08/21/19 09:42AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 03:32PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/21/19 08:13AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/21/19 08:17AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 04:01PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 04:10PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: live ɘvil live ɘvil 08/21/19 04:38PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 04:55PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: live ɘvil live ɘvil 08/21/19 06:37PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 06:57PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: live ɘvil live ɘvil 08/21/19 07:39PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 02:15PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 02:20PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 02:17PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 03:10PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/22/19 05:34PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 05:58PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Dave & Bummerzz Dave & Bummerzz 08/23/19 09:25AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 10:47AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 11:16AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 12:03PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/23/19 02:11PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 02:57PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/23/19 11:56AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 12:16PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 12:30PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 01:40PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 12:22PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 12:49PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 03:12PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/23/19 03:15PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 03:09PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 03:14PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 04:42PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Daniel '' Daniel '' 08/23/19 08:32PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 08:36PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Daniel '' Daniel '' 08/23/19 09:12PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 09:15PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Daniel '' Daniel '' 08/23/19 09:40PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/25/19 12:38PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Daniel '' Daniel '' 08/25/19 02:44PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/25/19 06:55PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 03:20PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 03:22PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 06:59PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/26/19 12:52PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/26/19 02:39PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/26/19 02:44PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/26/19 03:02PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/26/19 06:21PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 08:38PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 09:23PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/25/19 01:43PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/27/19 12:04AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/27/19 12:08AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: P D P D 08/27/19 09:49AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/27/19 01:02PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/27/19 10:09AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/27/19 12:09PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/27/19 01:03PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/28/19 03:59PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 03/06/20 12:46PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/28/19 04:05PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/28/19 11:48PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Jack Rutherford Jack Rutherford 08/29/19 08:48AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/29/19 10:57AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/29/19 12:19PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/29/19 12:33PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/29/19 04:24PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/30/19 01:07PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/30/19 03:37PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/29/19 09:42PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 03/05/20 07:39PM
