Re: PW65 Malossi with WWB ceramic bearings
Graham Motzing /
yeah thats what i'm talking about, the minarelli horizontal stuff is super well supported and not far off from a QT cylinder, and you can make an adapter for big hoggin reeds on the crankcase.
i don't know the hoca port maps at all, i installed one of their kits a long time ago on an express i think? i don't remember, fit and finish were ok. Taiwan mfg i think. anything nicasil is going to be worlds better than cast iron.
the minarelli horizontal stuff is all supported in 10 pin and 12 pin, the 10 pin is common on the yamaha (zuma, jog) where as the 12 pin is prevalent in many of the clones (TGB, etc). 47 mm '70cc' stuff for them is so common and you can get up to 20+ hp stage6 cylinders.
its definitely interesting to see what a pro porter would do with that malossi kit. i realized a long time ago its better to start with a more expensive kit, than put the time and money into trying to make a lower end kit work. Even having ported lower end kits to higher end port timings and specs on paper, they don't always perform as well because the transfer shape and direction has to be modified so much. I've taken a few cheap kits to the max with 10+ hour port jobs and its just not worth it if you value your time at all. you're better off starting with a good factory-designed kit that does what you want and making incremental changes a few degrees at a time until you find the sweet spot.
thats why i've never had much faith in anyone that does 'pro porting' because the only way to really max things out is guess and check and guess and check and tune and guess and check and tune and check... etc etc. the best money you can spend on dialing in a setup like this is buying about 10 base gaskets for the 10 times you will have that cylinder off making tiny changes. I've ported dozens of these cylinders and the only way to really get them running right is keep making small changes and just fine tuning.
having a dyno is awesome, that will certainly speed up development and let you really get it dialed.
  PW65 Malossi with WWB ceramic bearingsTopic by: mat hormell mat hormell 08/14/19 05:59PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: P D P D 08/14/19 06:11PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/14/19 06:16PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/14/19 06:17PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/14/19 06:19PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/14/19 06:18PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Jack Rutherford Jack Rutherford 08/15/19 09:24AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/15/19 10:41PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Dave & Bummerzz Dave & Bummerzz 08/15/19 10:03AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/15/19 10:46PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 09:17PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Dave & Bummerzz Dave & Bummerzz 08/16/19 10:08PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: alex . alex . 08/15/19 07:49PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/15/19 10:48PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/16/19 01:23AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 12:44PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 12:54PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 12:59PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/16/19 03:23PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 07:57PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/16/19 03:41PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 05:22PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 07:22PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/16/19 06:26PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 09:00PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/16/19 09:12PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/17/19 12:15PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/17/19 07:38PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/18/19 01:08AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: live ɘvil live ɘvil 08/21/19 09:42AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 03:32PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/21/19 08:13AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/21/19 08:17AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 04:01PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 04:10PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: live ɘvil live ɘvil 08/21/19 04:38PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 04:55PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: live ɘvil live ɘvil 08/21/19 06:37PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/21/19 06:57PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: live ɘvil live ɘvil 08/21/19 07:39PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 02:15PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 02:20PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 02:17PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 03:10PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/22/19 05:34PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/22/19 05:58PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Dave & Bummerzz Dave & Bummerzz 08/23/19 09:25AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 10:47AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 11:16AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 12:03PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/23/19 02:11PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 02:57PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/23/19 11:56AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 12:16PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 12:30PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 01:40PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 12:22PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 12:49PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 03:12PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/23/19 03:15PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 03:09PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 03:14PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 04:42PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Daniel '' Daniel '' 08/23/19 08:32PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 08:36PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Daniel '' Daniel '' 08/23/19 09:12PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 09:15PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Daniel '' Daniel '' 08/23/19 09:40PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/25/19 12:38PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Daniel '' Daniel '' 08/25/19 02:44PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/25/19 06:55PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 03:20PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/23/19 03:22PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 06:59PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/26/19 12:52PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/26/19 02:39PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/26/19 02:44PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/26/19 03:02PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Graham Motzing Graham Motzing 08/26/19 06:21PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 08:38PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/23/19 09:23PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/25/19 01:43PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/27/19 12:04AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/27/19 12:08AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: P D P D 08/27/19 09:49AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/27/19 01:02PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/27/19 10:09AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/27/19 12:09PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/27/19 01:03PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/28/19 03:59PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 03/06/20 12:46PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/28/19 04:05PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/28/19 11:48PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Jack Rutherford Jack Rutherford 08/29/19 08:48AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/29/19 10:57AM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/29/19 12:19PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Mikey Antonakakis Mikey Antonakakis 08/29/19 12:33PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/29/19 04:24PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: Anonymous User Anonymous User 08/30/19 01:07PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/30/19 03:37PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 08/29/19 09:42PM
  Re: PW65 Malossi with WWB ceramic bearingsRe: mat hormell mat hormell 03/05/20 07:39PM
