Slowing down a Maxi that's too fast for my son.
Jonathan Bennett /
I'm working on my son's Maxi to get it to a super quick but not too much top speed bike. At the moment it has a TCCD 50cc, 14mm Bing, Metal Mesh Filter, a Estoril Side Bleed and 15/36 gearing on it. Got it close on the tuning the other day and it clocked 43mph on a relatively flat road.
I rebuilt the engine but used the original crank, only 1000 miles on it, probably should have changed it out while I was in there, oh well...
The gear chart says that 43mph is 8000rpms. I'd really like to keep him around 35mph, which would mean changing out one of the gears to match the chart, say a 13/36 which would give 37mph at 8000rpms.
So my question is, does changing the gearing out run the risk of over revving the engine? Would my top rmp of 8000 go up because of the new gearing? Or is the top rpm regulated more by the cylinder/carb/intake/exhaust combo?
Re: Slowing down a Maxi that's too fast for my son.
Jack Rutherford /
why not just slightly over jet it?
Put a stack of washers on the throttle cable between the slide and top of carb so that you only get 3/4 throttle. You can put more or less to adjust it where you want.
put the stock air box back on it ¯\_(ツ)_/¯
it will be slower and a bunch quieter
treat it like a pw50 and limit the throttle cable.
Overpriced Parts /
Adjust throttle cable and or run 16x45 gears, that pipe will hold rpms back some, it’s not a real hi rpm pipe,
Or You can put your magnum XK set up on son’s bike with the stock magnum pipe, and you could put that TCCD set up with estoril pipe on your magnum so your bike is faster
Keep it how it is, it’s unsafe to be under powered, ya know. Tell him traffic situations and sometimes u gotta have a little extra.
It’s 35mph uphill tuning to keep up. Plus u don’t wanna have to wait to ride side by side, that puts u both at risk. Make it faster not slower. (edited)
You should get a faster son
Gearing is the best way to keep it from going too fast and it's something you would notice if he changed it back. just hide the old gears.
Hay Guise whinot titan tha BREAKS ? duhhhh
Just run even lower gearing, lower gearing you can hit higher revs. I'd put an 11t on that shit and it should do 32.
i doubt his stock crank would last long like that
Jonathan Bennett /
Yeah, I guess the question is two fold.
How do you have a super quick bike with a low top speed?
What does changing the gearing do to the life of the engine/crank?
Ken, I might just be doing that and putting that stuff on my Magnum. I did just order a circuit pipe to put on this Maxi. You can't spin the Maxi's pedals with this pipe without bending/extending/changing to a magnum pedal setup and spacer.
We will see what the circuit pipe does. If it's still too high a top speed, then I might change the front sprocket.
I've got almost same set up but with a proma GP on it and rito crank jammer clutch hitting 38 on stock 16x45 gearing
Jonathan Bennett /
Looks like about 8200 rpms. What's a safe number for a stock crank?
***VANILLA BLUNDER*** /
Stock pipe, boyeeeee
Overpriced Parts /
Don’t really know what’s safe, many puch cranks don’t even have a needle bearings in the bottom big end of the crank con rod just a bushing and there is only two tiny little slots for oil/gas mix to get in there,
The only real safe rpm and horsepower is stock configuration,
Richard Eberline /
Ken is correct, I have a few OEM cranks with brass on both ends. They are mean't for a stock set up or with a smaller pipe.
Jonathan Bennett /
What’s the best crank? Rito? Super Stuffy? Unstuffed?
This is the best idea I have heard I. A while for restriction.
Overpriced Parts /
Rito because most times you can use your stock clutch bell shims, basically a true bolt on,
The most logical thing to do is ride on back and yell in his ear SLOW DOOWwNn!!!
> DOOWwNn!!!
As you're screaming with fear for your life . LOL
i mean, really, a lot of the people posting on here with 10's of 1000's of miles under our belts riding mopeds will all tell you that having more speed and power available is safer in almost all driving situations. If he isn't responsible enough to control the moped at 43, he isn't ready for a moped period.
he problem with not giving it full throttle pull is that you don't get the power and accel at low rpms. I've dealt with that on the kiddie dirtbikes.
i think you could keep the stock crank in it, yeah the RPMs are bad for them but most of the damage is from increased load and heat from a kit. The 50cc puch kits are barely more power than stock so a clean stock crank should last just about forever.
How can I speed up my son?
It’s only 8 mph. Make sure he wears a helmet and let him make mistakes. If you’re really nervous upgrade the brakes to give him better capability to be able to slow down and avoid obstacles.
Overpriced Parts /
No that’s a fallacy, It is the rpm that’s mostly the problem,
Cranks do not last forever just because you’re running a 50cc kit not a 70cc kit unless you run stock rpm for some puch cranks don’t even have needle bearings at the bottom big end bearing and have only teeny tiny little oil grooves in con rod at big end so very little lube gets in to big end or to the sides of the big end of the Conrod unlike the small end of the rod because it has a oil hole,
This crank (which was low mi and in great shape to begin with) got the big end of con rod side friction welded to the crank lobes when upped the RPM to around 9,000 rpm but still running the stock 50cc cylinder, It ran good full synthetic motor oil and a heavy 50 to 1 mix more like a 45 to 1 mix,
I’ve had several puch stock crank lock ups when I upped the rpm and for me it was always the big end of the rod and always same thing: Rod was friction welded to the side of the lobes something like this:
Reed type kits/cylinders take a bigger jet and have a more gas oil in air mixture into the crankcase and you may be able to get a bit more RPM out of them if you want to try before they lock up but regular piston port kits run a smaller/leaner jet so there’s less gas in the air mix and less getting to the sides of the crank so rpms need to be kept down
♣Slew Foot♣ /
This has to go in the highlight reel...
welp (edited)
> Becca C. Wrote:
> welp
So , you're disappointed ?
